Max Area Rectangle on y=cosx Curve
  • Thread starter Thread starter ryan.1015
    Area
The problem involves finding the dimensions of a rectangle with the largest area that has its base on the x-axis and vertices on the curve defined by y=cos(x). The objective is to maximize the area of the rectangle under these constraints.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss formulating the area equation A=2xy, substituting y with cos(x), and taking the derivative to find critical points. There is mention of encountering a transcendental equation, cot(x)=x, and the challenges associated with solving it. Some suggest trial solutions and numerical methods to find approximate values.
The discussion is ongoing, with participants exploring different approaches to solving the transcendental equation. Some guidance has been offered regarding the formulation of the area and the derivative, but no consensus has been reached on the solution method or specific values.
Participants note the potential complexity of the problem, indicating that it may not yield a straightforward analytical solution and may require numerical methods or approximations.
ryan.1015
find, correct to five decimal places, the dimensions of the rectangle of largest area that has its base on the x-axis and its other two vertices above the x-axis and lying on the curve y=cosx
this is a standard calc min/max problem. First make an equation of what you want to maximize
A=bh
the base is 2 times your x coordinate, and your height is just y so:
A= 2xy
now substute in your restraint equation y = cos(x)
A=2xcos(x)
now take the derivative with respect to x and set equal to zero. The solution should be the correct x value
I'm getting a transcendental equation out of this cot(x)=x, guess you have to solve with your calculator from there unless I am making some mistake somewhere, usually these types of problems are a little cleaner to solve.
That's what I get, so I think you're on the right track. A trial solution is x = pi/4, for which cot(pi/4) = 1. Those values aren't too far apart. I would keep trying different values, looking for values for which x and cot(x) are closer together, stopping when I get them to agree in 5 decimal places.
