Why is brass resistant to corrosion?
  • Thread starter Thread starter KAS90
Brass, an alloy of copper and zinc, exhibits corrosion resistance primarily due to the presence of zinc, which acts as an electron donor. When copper begins to oxidize, zinc donates electrons to replace those lost by copper, thus delaying corrosion. However, if the zinc content exceeds 15%, this protective mechanism is compromised, leading to increased susceptibility to corrosion. This phenomenon is similar to the use of zinc coatings on nails to prevent rusting.
  • Understanding of alloy composition, specifically copper and zinc ratios
  • Basic knowledge of electrochemistry, particularly electron donation and oxidation
  • Familiarity with corrosion mechanisms in metals
  • Awareness of protective coatings and their applications in metal preservation
  • Research the electrochemical properties of copper and zinc in alloys
  • Explore the effects of varying zinc percentages on brass corrosion resistance
  • Learn about corrosion prevention techniques, including galvanization
  • Investigate other metal alloys and their corrosion resistance properties
Materials scientists, metallurgists, and engineers involved in alloy development and corrosion prevention strategies.
KAS90
hey there..
I read that brass "an alloy of copper and zinc" doesn't corrode unless more than 15% of zinc is added..
My question is.. what is the reason behind the resistance of corrosion of brass? does it have 2 do with the electronegativity or sumthing like that?
I'd appreciate ur response and help a lot..
Thanks in advance..
It would eventually corrode. But the way it works is that zinc is an electron donor. When the copper is ready to corrode, or oxidise (lost an electron), the zinc is there waiting to give it another to replace the lost electron. Obviously this cannot go on indefinately. Its the same reason why we get zinc coated nails etc.
As to why is corrodes if more than 15% is added... No idea.
  • · Replies 16 ·
20K
  • · Replies 43 ·
12K
