Calculating Weight to Make Balloon Rise 116m in 17s Using Archimedes Principle
The discussion revolves around a physics problem involving a lighter-than-air spherical balloon, its load, and the application of Archimedes' principle to determine the weight that must be dropped to make the balloon rise a specified distance in a given time. The problem involves concepts of buoyancy and forces acting on the balloon.
  • The original poster attempts to apply Archimedes' principle to find the buoyant force and relates it to the weight of the balloon to determine the resultant force needed for ascent. They question how to find the initial mass of the balloon to calculate the required weight to be dropped.
Participants are exploring the equilibrium of forces acting on the balloon, with some confirming the relationship between the weight of the balloon and the buoyant force. There is an ongoing inquiry into the assumptions made and the necessary calculations to progress in solving the problem.
The problem involves specific parameters such as the radius of the balloon and the density of air, which are critical for calculations but may not be fully utilized or understood by all participants. The discussion reflects uncertainty regarding the initial conditions and required outcomes.
moeraeleizhaj
A lighter-than-air spherical balloon and its load of passengers and ballast are floating stationary above the earth. Ballast is weight (of negligible volume) that can be dropped overboard to make the balloon rise. The radius of this balloon is 6.59 m. Assuming a constant value of 1.29 kg/m3 for the density of air, determine how much weight must be dropped overboard to make the balloon rise 116 m in 17.0 s.
Hi, that's a physics problem aht confounds me.
It's about archimedes principle (weight of fluid displaced=buoyant force) , right? I've found out the buoyant force using that principle.
And the part when the balloon moves can be solved by doing (buoyant force-weight of the balloon=Resultant force) wherein the resultant force causes the balloon to rise up(resultant force=mass of balloon*vel (116-17)). Is that assumption right? if i do that i get the new mass of the balloon but i don't know how to get it's intial mass and i need it to find out how much mass needs to be dropped.
Can anyone help me with my problem please?
What can you deduce from this statement?
that the forces are in equlibruim .'. the weight of the balloon=the buoyant force?
Exactly.
12K
12K
