Max extension of spring/ magnitude of its acceleration
The discussion focuses on calculating the maximum extension and acceleration of a spring with a spring constant of k = 30 N/m when a 1.1 kg mass is attached. The maximum extension (x) is determined using the formula x = mg/k, yielding a value of approximately 0.35933 m. However, the user encounters an error in their calculations, prompting a suggestion to apply the conservation of energy principle, where gravitational potential energy equals spring potential energy (PE = PE), to find the correct maximum extension and subsequently the maximum acceleration using a(max) = (A)(w^2).
  • Understanding of Hooke's Law and spring constants
  • Basic knowledge of oscillatory motion and acceleration
  • Familiarity with gravitational force calculations
  • Concept of conservation of energy in mechanical systems
  • Review the derivation of the spring constant and its implications in oscillatory systems
  • Learn about the conservation of energy in mechanical systems, specifically in springs
  • Study the relationship between amplitude, angular frequency, and maximum acceleration in harmonic motion
  • Explore the effects of mass and spring constant on the period of oscillation
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to springs and energy conservation.
WPCareyDevil
An ideal spring has a spring constant k = 30 N/m. The spring is suspended vertically. A 1.1 kg body is attached to the unstretched spring and released. It then performs oscillations.
(a) What is the magnitude of the acceleration of the body when the extension of the spring is a maximum in m/s^2
(b) What is the maximum extension of the spring in m?
kx=mg
=> x=mg/k
a(max)=(A)(w^2)
w=2pi/T
T=2pi*(sqrt(m/k))
k=30
m=1.1
a=?
x=?
I have to solve part B (amplitude) before I can solve part A. So, simple algebra sets
x=mg/k
x=(1.1)(9.8) / 30
=.35933 m
But this is wrong according to web assign. Could you tell me what I am doing wrong? Perhaps units or something?
Thank you!
You might want to account for the conservation of energy:
PE = PE
m*g*x = 1/2*k*x²
At the minimum extension (starting point) all energy is gravitational; at the maximum extension, all energy is in the spring. This is how you solve b.
Only at the equilibrium point midway between is kx = mg.
  • · Replies 17 ·
