Existence of Derivatives in a Neighborhood
  • Context: Graduate
  • Thread starter Thread starter e(ho0n3
    Derivatives Existence
The discussion revolves around the existence and continuity of derivatives for a real-valued function defined on an open interval, particularly focusing on the implications of a function being twice differentiable at a point. Participants explore whether the existence of a derivative at a point guarantees its existence in a neighborhood around that point.
  • Some participants assert that if a function f is twice differentiable at a point u, then f' is continuous at u.
  • Others caution that while f' may be continuous at u, it does not necessarily imply that f' is differentiable in a neighborhood of u, citing examples of functions that are continuous but not differentiable.
  • A participant questions the proof of the continuity of f' using the epsilon-delta definition, noting that this definition assumes the function is well-defined in a neighborhood.
  • Another participant emphasizes that the existence of f' at a point implies that f must exist in some neighborhood around that point, arguing that this is a matter of definition rather than proof.
  • Some participants discuss the implications of discontinuities, stating that a derivative cannot exist at points of discontinuity.
Participants express differing views on the implications of differentiability and continuity, with some agreeing on the definitions while others raise concerns about the assumptions involved. The discussion remains unresolved regarding the broader implications of these definitions.
There are limitations in the assumptions made about the continuity and differentiability of functions, particularly in relation to the definitions used and the examples provided. The discussion highlights the need for careful consideration of these definitions in proofs.
e(ho0n3
Simple question: Let f be a real-valued function defined an open interval U. If f is twice differentiable at u, then f' is continuous at u right? Does that mean that there exists a neighborhood around u where f' exists for all points in this neighborhood?
That is true, however, keep in mind that f' may not be differentiable in a neighborhood of u (ie., think of the infamous function f(x) = x for rational x, and 0 otherwise, which is only continuous at 0).
What would be the proof of this though? If I use the epsilon-delta definition of the derivative for f' at u, we get the following:
For any e > 0 there is a d > 0 such that |x - u| < d implies |f'(x) - f'(u) - f''(u)(x - u)| < e|x - u|.
This doesn't say that f'(x) exists for x satisfying |x - u| <d because the epsilon-delta definition assumes the function is already defined properly, so as a matter of fact, we can't even employ the epsilon-delta definition.
e(ho0n3 said:
Simple question: Let f be a real-valued function defined an open interval U. If f is twice differentiable at u, then f' is continuous at u right?(2) Does that mean that there exists a neighborhood around u where f' exists for all points in this neighborhood?(1)
An answer to 1:
Consider the following question: "If [tex]f'(x_0)[/tex] exists, then does [tex]f(x)[/tex] exist for [tex]x_0-\delta < x < x_0+\delta[/tex] with some delta?"
Do you see why that is confusing question? The derivative is defined by the formula
[tex] f'(x_0) = \lim_{h\to 0} \frac{f(x_0 + h) - f(x_0)}{h},[/tex]
so you cannot define the derivative in the first place, if f doesn't exist in some environment of [tex]x_0[/tex]. In any case, the answer to the question is "yes", because by definition, the f must have existed before the derivative was defined. It is not a kind of thing you prove, instead you read it from the definition.
In your original question you made this one step trickier by assuming that [tex]f''(x_0)[/tex] exists, and then asked about [tex]f'(x)[/tex] in the environment. But it's the same thing.
An answer to 2:
A derivative never exists in a point of discontinuity.
jostpuur said:
An answer to 1:
Thanks for the clarification. I think I can also argue by contradiction: if f' was not defined for any neighborhood around u, then f''(u) would not exists by definition.
