Impact area of a steel ball on a surface
The discussion focuses on determining the impact area of a steel ball on various surfaces during impact testing. Key concepts include Hertzian contact mechanics, which describes the contact area based on the radii, elastic modulus, and Poisson's ratio of the materials involved. The conversation also highlights the relevance of measuring force (F=ma) versus pressure (P=F/A) in evaluating material strength. Advanced techniques such as double-pulse holographic interferometry are mentioned for measuring surface deformation, although simpler methods may suffice for basic analysis.
  • Understanding of Hertzian contact mechanics
  • Familiarity with elastic modulus and Poisson's ratio
  • Knowledge of force and pressure calculations (F=ma, P=F/A)
  • Basic principles of holographic interferometry
  • Research Hertzian contact mechanics in detail
  • Study the principles of elastic modulus and Poisson's ratio
  • Learn about force and pressure calculations in material testing
  • Explore applications of holographic interferometry in impact testing
Material scientists, mechanical engineers, and researchers involved in impact testing and material strength evaluation will benefit from this discussion.
J_chem
Hey everyone.
I'm doing some impact testing, and I'm dropping a steel ball from different heights to test the strength of different materials.
How would I go about finding the impact area of the steel ball on the surface?
Thanks!
edit: also, does area matter? would I be better off rating these materials by force (F=ma) in which case contact area would be irrelevant...
or Pressure (P = F/A) in which case I would need to know the contact area of a steel ball on a surface?
Thanks again for any info
It might be too advanced for what you are after/or can afford, but the following is from this source: http://cat.inist.fr/?aModele=afficheN&cpsidt=3665665
The surface deformation which is caused by such an impact was measured by means of double-pulse holographic interferometry. Because of the small amplitude of the surface waves quasi-heterodyne holographic interferometry was required. The areas of initial wear of the materials can be recognized by the disturbed propagation of the surface waves.
There might be simpler methods out there.
The contact area of a steel ball on a surface is best described by Hertzian contact mechanics. A good tribology or mechanics textbook will help with this, but essentially it depends on the radii, elastic modulus and Poisson's ratio of the two objects.
Please check my response to your other post for a better approach in your case; contact mechanics is a great way to analyse an impact such as this, but for your requirements you're probably after something a little more straightforward.
HTH,
Tim
21K
  • · Replies 45 ·
  • · Replies 64 ·
