Total Momentum of the Universe
  • Context: Graduate
  • Thread starter Thread starter Antonio Lao
    Momentum Universe
The discussion centers around the concept of the total linear momentum of the universe, exploring whether it can be zero. Participants examine the implications of the universe's expansion, reference frames, and the complexities of cosmic motion, including angular momentum and energy transformations.
  • Some participants propose that the total linear momentum of the universe could be zero, as the universe as a whole is not moving, although it is expanding.
  • Others suggest that the velocities of galaxies could cancel each other out, with equal and opposite movements contributing to a net momentum of zero.
  • A later reply introduces the complexity of tracking cosmic movements due to additional factors like angular momentum and energy transformations, suggesting that the dynamics of the universe are intricate.
  • One participant questions whether it is possible to choose an inertial reference frame where the universe does not have zero linear momentum, highlighting the role of reference frames in physics.
  • Another participant argues against the necessity of reference frames in formulating physical theories, suggesting that they complicate rather than simplify the search for truth.
  • Conversely, a different viewpoint emphasizes that reference frames are essential for making general statements in physics and for verifying results across different observers.
  • There is a suggestion that if the universe is spinning, this could influence the movement of galaxies, raising further questions about the nature of reference frames and their distribution in the universe.
  • One participant asserts that if the Big Bang model is correct, the total linear momentum must be zero, as all matter was initially compacted and thus had no velocity relative to anything else.
  • Another participant questions the need for reference frames when discussing concepts like vacuum and force, suggesting that these concepts reference themselves.
Participants express multiple competing views regarding the total linear momentum of the universe, the role of reference frames, and the implications of the Big Bang model. The discussion remains unresolved with no consensus reached.
Limitations include the dependence on assumptions about the universe's motion and the complexities introduced by angular momentum and energy transformations. The discussion also reflects varying interpretations of reference frames in theoretical physics.
Antonio Lao
Can the total linear momentum of the universe be zero? Momentum is defined as the product of mass and velocity. But the universe as a whole is not moving (an assumption) although it is expanding therefore velocity=zero. To really see whether the universe is moving or not, a vantage point outside of spacetime is needed. But this is impossible.
Could not also the total velocities cancel out? I.e. for every galaxy heading in one direction at x speed, there is an equal and opposite galaxy traveling at -x speed. I'm not an expert on physics though.
:smile:
In reality, it's a lot more complex than that. There are also angular momenta and energy transformation (potential to kinetic and vice versa). With these other parameters, it is next to impossible to track all the movements of stars and galaxies, clusters and superclusters. The movements seem to conform to some fractal geometries (existence of self-similarities and great attractors, bifurcations, etc) inherent in nature.
Obviously, you can choose an inertial reference frame for which the universe has 0 linear momentum. The more difficult question is; can you choose an inertial reference frame for which the universe does not have 0 linear momentum?
Njorl
Njorl said:
...choose an inertial reference frame...
Do we really need any reference frame (inertial or otherwise) in order to formulate a new physical theory. To keep it frugal and simple, any reference frame is a luxury that any poor theorist cannot afford. Frame needs math and more frames need more complicated math. One can stuck one's whole lifetime just by learning everything in math and still would be farther from the truth sought originally in the theory. Math should never be the master of the search for truth but as a mean, not the end of the search. Math is best if it is the mean to an end.
You seem to have the idea that a reference frame is a complicating feature and we should try to live without it. On the contrary, reference frames are simplifying constructs. They are simply a fixed set of conditions from which measurements are made, so that others can set up the same conditions and verify the results. No general statements can be made in physics unless such conditions are controlled. To take a simple example, I can tell my neighbour that the sun always rises over the tree in my back yard. If he verifies this from his house (frame), he will see it to be false.
The question Njorl asks is fundamental. A second one is "Is the universe spinning?"
If the universe is spinning this could be why galaxies are moving apart.
Is there an inertial reference frame for which the universe does not have zero linear momentum?
This can only be the case if there are any reference frames that do not accelerate or rotate? There could be briefly but since the masses in the universe are dynamic
such a reference frame could only exist for a fraction of a second.If there was more than one inertial frame at anyone time then it would be interesting to know how these frames are spatially distributed-it would imply an order in the universe we don't currently know about.
Well assumming the Big bang model is correct in in some form (namely that the universe is expanding from an intial explosion) the the total linear momentum would have to be zero (measured of course from the fram of reference of the whole universe) because the initial linear momentum previous to the expansion would have been zero (because there can be no velocity if all matter is compacted into one object, that one object can never have a velocity because there is nothing for it to be moving relative to.) So the total linear momentum must be zero.
krab said:
You seem to have the idea that a reference frame is a complicating feature...
If I was going to formulate a theory of the vacuum, do I need a reference frame? In this case the vacuum is referencing itself. If I was going to formulate a quantum theory of spacetime, do I need another spacetime frame? Again, spacetime is referencing itself. What is the meaning when we say that a distance is zero? What are we referencing it to? What is the meaning when we say that a force is zero? If the force is not zero then we can introduce a frame to indicate that the force varies from point to point and forming a force field.
  • · Replies 60 ·
  • · Replies 21 ·
  • · Replies 53 ·
  • · Replies 36 ·
16K
  • · Replies 21 ·
  • · Replies 35 ·
