Light Intensity at Point Sources: Impact on Energy Falloff?
  • Context: Undergrad
  • Thread starter Thread starter djmike
    Light Point Sources
The discussion centers on the relationship between light intensity at point sources and energy falloff, specifically referencing the inverse square law. It concludes that if two light sources emit equivalent intensity, the energy received at a given distance will be the same, regardless of the source type. An example provided illustrates that replacing the sun with billions of candles to match its brightness would yield similar visual effects at a distance, such as on Pluto, although differences may be noticeable at closer ranges.
  • Understanding of the inverse square law of light intensity
  • Basic knowledge of light sources and their properties
  • Familiarity with concepts of energy falloff in physics
  • Awareness of how distance affects light perception
  • Research the inverse square law in detail
  • Explore the physics of light sources and their intensity
  • Investigate how distance impacts light visibility and perception
  • Study the effects of different light sources on energy distribution
Physicists, educators, students in optics, and anyone interested in the principles of light behavior and energy distribution.
djmike
i am a little confused as to whether light intensity at a point source is critical to how the energy will fall off(i know inverse sq ). if there is equivalent intensity from 2 sources will there be the same energy at any given distance?
sorry if that is a little convoluted... here is a more specific example...
if the sun was replaced by billions of candles so it was as bright as the normal sun here on earth, would it still look the same as the sun would furthor away, say on pluto??
Science news on Phys.org
Essentially yes. Only if you are close could there be a signigficant difference between the two cases.
