Word problem using derivatives - struggling with it
The discussion centers on applying derivatives to Boyle's Law, represented by the equation PV = c, where P is pressure, V is volume, and c is a constant. The user seeks assistance in determining the rate of change of pressure (dp/dt) when the volume is decreasing at a rate of 10 cm³/min, with initial conditions of pressure at 100 g/cm² and volume at 20 cm³. The correct approach involves using the product rule for differentiation, leading to the equation dp/dt = - (P/V) * (dv/dt). This formula allows for the calculation of dp/dt by substituting the known values.
  • Understanding of Boyle's Law and its mathematical representation
  • Knowledge of derivatives and differentiation techniques
  • Familiarity with the product rule in calculus
  • Ability to solve algebraic equations
  • Study the product rule in calculus for differentiating products of functions
  • Practice solving related rates problems in physics
  • Explore applications of Boyle's Law in real-world scenarios
  • Learn how to apply derivatives in various physical contexts
Students studying calculus, particularly those focusing on applications of derivatives in physics, as well as educators seeking to clarify concepts related to Boyle's Law and related rates.
meredith
the equation is PV = c; p = pressure, v = volume, c=constant. (also known as Boyle's law)
the question: if volume is decreasing at a rate of 10cm^3/minute, how fast is the pressure increasing when the pressure is 100g/cm^2 and volume is 20 cm^3
none
dv/dt = -10cm^3/min
dp/dt = ?
equation: PV=c
derivative:
dp/dt x dv/dt = 0
dp/dt = -dv/dt
but i know what I am doing isn't right. can anyone help me? THANKS!
none
dv/dt = -10cm^3/min
dp/dt = ?
equation: PV=c
derivative:
dp/dt x dv/dt = 0
The above isn't right. It is not true that d/dt(PV) = dP/dt * dV/dt. You need to use the product rule.
meredith said:
dp/dt = -dv/dt
After you differentiate PV, solve algebraically for dP/dt, and then substitute the values you have.
  • · Replies 18 ·
  • · Replies 30 ·
