| Thread Closed |
mass & weight conversion :$ |
Share Thread |
| Nov29-08, 07:21 AM | #1 |
A number of objects are taken to the moon, where the acceleration due to gravity is about 1/6 of earth's.Complete the following table: Item----------Mass on Earth-----Mass on Moon-----Weight on Moon---Weight on Moon Paper clip ---------1.2 g -------------- g --------------g(f) --------------- dyne Can of cola -------0.56 lb(m)----------lb(m) ------------lb(f) -- ------------- pdl Hammer------------1.3 kg -------------kg -------------kg(f) ----------------- N 2. Relevant equations 3. The attempt at a solution I think the mass on Moon will not change..right??! the weight on Moon(the third column ) = mass*9.8*1/6 ...!! what is ( dyne, pdl,N)?!! How to convert to these units ?? THANX =) |
| Nov29-08, 08:41 AM | #2 |
Mentor
Moon weight = mass * g * (1/6)The numerical value of g depends on what system of units are being used. It's 9.8 m/s^2, but if you use cm or inches then it would be different than 9.8 pdl is an abbreviation for poundals (different than pounds) N is Newtons. |
| Nov29-08, 09:44 AM | #3 |
Redbelly98
Thank you very much.. Where can I get the formulas to convert into these units?! |
| Nov29-08, 09:46 AM | #4 |
The numerical value of g depends on what system of units are being used. It's 9.8 m/s^2, but if you use cm or inches then it would be different than 9.8 If I am using cm or inches .. what will the value be ?? thanx again =) |
| Nov29-08, 09:58 PM | #5 |
Mentor
To convert 9.8 m/s^2 into the other units, use these facts:
1 m = ____ cm? 1 m = ____ inches? From those conversion factors, use the normal methods for converting units. You might try a google search to see what dynes, poundals, or Newtons are. But your teacher/professor really should have talked about these in class already. Seriously, if he did not at least discuss what a Newton is, he should be fired. EDIT. The poundal is a rather obscure unit. I did find this info: http://en.wikipedia.org/wiki/Poundal |
| Thread Closed |
Similar discussions for: mass & weight conversion :$
| Energy<>Mass conversion | General Physics | 10 | ||
| Basic mass to weigh conversion??? | Introductory Physics Homework | 2 | ||
| Conversion of mass to energy | Special & General Relativity | 9 | ||
| Conversion of mass to energy | Atomic, Solid State, Comp. Physics | 1 | ||
| Conversion of mass to energy | High Energy, Nuclear, Particle Physics | 0 | ||
