Proving Martingale Property and Stopping Theorem for Probability Homework
The discussion revolves around proving the martingale property and applying the stopping theorem in the context of a probability problem involving an urn model with white and black balls. The original poster attempts to define a sequence related to the number of white balls and explore its martingale characteristics.
  • Participants discuss the definition of a martingale and its application to the defined sequence. There are attempts to calculate expectations based on the urn's composition after each replication. Questions arise regarding the probabilities associated with drawing different colored balls and how these affect the martingale property.
Some participants have provided guidance on calculating expectations and exploring the implications of the urn model. There is ongoing exploration of the relationship between the defined sequence and the martingale property, as well as the application of the stopping theorem.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is a focus on ensuring that the definitions and calculations align with the requirements of the problem.
dirk_mec1
http://img128.imageshack.us/img128/2010/95701129si7.png
If I define [tex]Z_n = \frac{X_n}{n+2}[/tex] with Xn the number of white balls in stage n then how can I prove that it's martingale?
To start with, what is the definition of a martingale?
Do you know the answer to the question or are you teaching me?
[tex]E[ Z_{n+1}| Z_1 ,Z_2,...,Z_n] =Z_n[/tex]
1) After the nth replication, there are [tex]Z_n(n+2)[/tex] white balls and [tex](1-Z_n)(n+2)[/tex] black balls in the urn.
2) In the (n+1)th replication, there will either be a white ball or a black ball added into the urn. For each of these cases, what will the new proportion of white balls in the urn be and what are the associated probabilities? Use the definition of expectation to calculate [tex]E \ [\ Z_{n+1}\ | \ Z_{1} , \ Z_{2} \, ..., \ Z_{n} \ ][/tex]
I thought that at each replication two white balls are added or removed. But suppose you're right then I get:
[tex]Z_{n+1}= \frac{Z_n(n+2)+1}{n+3}[/tex]
[tex]Z_{n+1} = \frac{Z_n(n+2)-1}{n+3}[/tex]
with probabilities 1/2 for each?
At each replication, a ball is drawn from the urn. The colour of the ball is noted, then that ball, together with a new ball of the same colour, are placed into the urn. Note then that after each replication, the number of white balls in the urn either stays the same or increases by one.
Now, what is the probability of drawing a white ball (similarly, a black ball) from the urn during the (n+1)th replication? (Not necessarily half!)
If a white ball is drawn during the (n+1)th replication, then that white ball will be put back into the urn and a new white ball added. So, what will the proportion of white balls be after the (n+1)th replication? Similarly, if a black ball is drawn during the (n+1)th replication, what will the new proportion of white balls in the urn be?
So
[tex]E[Z_{n+1}|Z_1,...,Z_n] = Z_n \cdot \frac{Z_n (n+2) +1}{n+3} +(1-Z_n) \cdot \frac{Z_n (n+2) +1}{n+3} =Z_n[/tex]
Ok thanks. The next question is:
if T is the first stage at which a black ball is drawn prove that then:[tex]E \left[ \frac{1}{T+2} \right] - \frac{1}{4}[/tex] via the martingale stopping theorem.
http://img45.imageshack.us/img45/2362/85438730sk6.png If X_N is the number of white balls in stage n then:
[tex]E[Z_T] = E[Z_1] = \frac{1}{2} = E \left[ \frac{X_T}{T+2} \right] = E[X_T] E \left[ \frac{1}{T+2} \right][/tex]
Is this correct?
