Proove Series Question: Solving the Challenge
  • Thread starter Thread starter transgalactic
    Series
The discussion revolves around a question related to sequences and their convergence, specifically focusing on the relationship between two sequences, \( a_n \) and \( b_n \), and their limits. Participants are exploring definitions and properties of convergence in the context of a given problem.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the definition of convergence and its implications for sequences. There are attempts to relate the behavior of \( b_n \) to the convergence of \( a_n \). Questions arise about the role of \( N \) in the definition of convergence and how it applies to specific examples. Some participants express uncertainty about how to proceed without a specific formula for the sequence \( a_n \).
The conversation is ongoing, with participants offering insights into the definitions and properties of convergent sequences. There is a mix of interpretations regarding the relationship between the sequences and the implications of convergence. Some participants have provided clarifications and examples, while others are still seeking direction on how to apply these concepts to the original problem.
Participants note that the original poster is only given that the sequence \( a_n \) converges to a value \( a \), which raises questions about the lack of additional information or a specific formula for \( a_n \). There is also mention of the need for clarity on whether \( a_n \) is monotonic, which affects the reasoning about \( b_n \).
transgalactic
the question in this link:
http://img372.imageshack.us/img372/7929/76106583tn6.gif
This looks like a question about sequences, not series. Have you tried doing anything yet? The definition of convergence seems like a good place to start
this question is obvious
its common sense
if a(n) converges to a
then if we take the function who takes the biggest member
of course it will pick the closest to "a"
i don't know how to transform these word into math
Definition of convergence: For all e>0, there exists N>0 such that n>N implies |an - a| < e
So... if you take n>N, what can you say about |bn-a|?
|bn-a|<e
this inequality shows that b(n) has not reached the bound
what is the next step?
So given e>0, can you find N such that n>N implies |bn-a| < e?
whats the role of "N"
why are you writing N>0 n>N ??
instead you could write just n>0
It is not for any n > 0 . For example, consider the sequence {1, 1, 3, 3, 4, 5, 5, 5, 5, 5, 5, 5, 5 ... etc} that converges to 5. Here our N is 6 since for any n > N, |a_n - 5| < e. So the role of N is to show that once you pass a_N, the sequence has essentially converged.
Think about what is going on in the sequence b. Are it's entries similar to those in a_n? What happens when you take a very large n?
why in this example our N is 6?
the definition of a couchy sequesnse is:
after a finite number of steps, any pair chosen from the remaining terms will be within distance "e" of each other.
i can guess that for each bn
it take the largest member from a1 to an
for example:
a1=6 a2=5 a3=6 a4=1 a5=8 a6=7
b1=6 b2=6 b3=6 b4=6 b5=8 b6=8
what to do now?
anyone?
N is 6 because after 6 steps, any pair of terms is "0" away from each other, so they are certainly less than "e" away from each other. So in general, N is the number of finite steps you must advance before "any pair chosen from the remaining terms will be within distance "e" of each other". This is more of an aid to visualize things and to keep things formal.
You may want to consult some of the theorems from real analysis like monotone convergence.
We're not talking about Cauchy sequences, we're talking about convergent sequences. They happen to be equivalent, but when you're proving something is convergent it's often easier to just prove it's convergent. I posted the definition of a convergent sequence above. In the example Vee gave, N (in the definition of convergence, whose relevance I'll go into deeper later) is 6 since after 6 steps, you reach the limit point (and hence for any e>0, |an - 5| = 0 < e.
The point of saying N>0 isn't to indicate that n>0 later, the point is that you have to pick a very large number (like you said, some finite number of steps). So given e>0, there exists N (whose value you don't know) such that n>N implies |an - a|<e. For small e, N is going to be something like 10,000 or 100,000. This isn't the same as just saying n>0
ok i understand after N step we have the members |bN-b(N+1)| < e
and when we take n>N its an over kill(to be absolutely sure)
but in this question i don't have the formula of sequence "a"
so i can't do this process
how to apply this process on my question?
i am only given that sequence An converges to the value "a"
i could say that if An s monotonic and converges then An+1 also converges to "a"
so Bn ->a
but here i can't say that An is monotonic
