Is 1/2ln(a+4)+ln(b)-5ln(c) equal to ln(b/(c^5(a+4)^(1/2)))?
  • Thread starter Thread starter elie_girl
The discussion revolves around the simplification of a logarithmic expression involving variables a, b, and c. Participants are examining whether the expression 1/2ln(a+4)+ln(b)-5ln(c) can be correctly represented as ln(b/(c^5(a+4)^(1/2))).
  • Conceptual clarification, Mathematical reasoning
  • Participants are considering the simplification of the logarithmic expression and questioning the correct placement of terms in the numerator and denominator. There is a focus on ensuring clarity in the formatting of the expression for submission.
The discussion is active with participants exploring different interpretations of the expression's format. Some guidance has been offered regarding the use of parentheses for clarity, but there is no explicit consensus on the final form of the expression.
Participants mention the need for a specific format due to submission requirements, indicating that clarity in the expression is crucial for correctness in the context of their homework.
elie_girl
1/2ln(a+4)+ln(b)-5ln(c) is the answer ln b/c^5(a+4)^1/2 ?
I just need to know if this answer is right,and should the format of the equation look like that also? Because the Math palette I submit it in needs to have it a certain way or else it will mark it as wrong.
If you are to simplify it then I would say so. Just use another set of parenthesis to separate the b/c^5 from the (a+4)^1/2 since it would be hard to tell if the (a+4)^1/2 is on the numerator or denominator.
So then (a+4)^1/2 should be the denominator?
No it's in the numerator, only the c5 is in the denominator.
