Spontaneity of reactions and free energy
A reaction occurs at constant temperature if the change in Helmholtz free energy (A) is negative, and at constant temperature and pressure if the change in Gibbs free energy (G) is negative. The discussion critiques existing proofs that rely on the assumption that entropy change (ΔS) is derived from reversible heat exchange (ΔQ/T), arguing that this is unjustified for irreversible chemical reactions. It emphasizes that while real-life processes are irreversible, examining reactions at the molecular level reveals reversible characteristics. The energy equation dE=T\,dS-p\,dV+\sum\mu\,dN is applicable for systems in equilibrium, leading to the Gibbs free energy spontaneity criterion through a Legendre transform.
  • Understanding of Helmholtz free energy (A) and Gibbs free energy (G)
  • Knowledge of entropy change (ΔS) and its relation to heat exchange
  • Familiarity with the energy equation dE=T\,dS-p\,dV+\sum\mu\,dN
  • Concept of reversible versus irreversible processes in thermodynamics
  • Study the derivation of the Helmholtz free energy and its applications in thermodynamics
  • Learn about the Gibbs free energy and its role in predicting reaction spontaneity
  • Explore the concept of entropy in irreversible processes and its implications
  • Investigate Legendre transforms and their applications in thermodynamic equations
Chemists, thermodynamics students, and researchers interested in the spontaneity of chemical reactions and the principles governing energy changes in systems.
jdstokes
Does anyone know of a clean proof that a reaction will occur at constant temperature if the change in Helmholtz free energy is negative, or at constant temperature and pressure if the change in Gibbs free energy is negative?
The only `proofs' I've found rely on the fact that the entropy change of the system is given by [itex]\Delta Q /T[/itex]. It seems to me as though this assumption is unjustified since the relation [itex]\Delta S = \Delta Q /T[/itex] holds only for reversibly exchanged heat, but chemical reactions are irreversible processes in general.
It's true that all real-life processes are irreversible. But as we narrow our focus from a laboratory to a calorimeter to a micro-scale region of gas to individual atoms, things look more and more reversible. After all, irreversibility is caused by smoothing of energy gradients over spatial regions, so let's consider only the smallest regions. Reactions are reversible at the molecular level; it's the dispersion of heat, momentum, mass, etc. to other areas that is irreversible. That's why the [itex]\Delta H=0[/itex] and [itex]\Delta G=0[/itex] criteria are still useful.
Another way of looking at it is that the energy equation [itex]dE=T\,dS-p\,dV+\sum\mu\,dN[/itex] holds for a system in equilibrium. As before, the closer we look, the more things look like they're at equilibrium. Now do a Legendre transform to get [itex]dG=-S\,dT+V\,dp+\sum\mu\,dN=0[/itex] at constant temperature, pressure, and mass, and we have your Gibbs free energy spontaneity criterion again.
  • · Replies 16 ·
