Thermodynamics involving rods and heat transfer with conduction
The discussion focuses on heat conduction between two identical rectangular metal rods, one at 0 degrees Celsius and the other at 100 degrees Celsius. In a scenario where the rods are welded end to end, 10 joules of heat is conducted in 2 minutes. The main question arises when considering the configuration change to side by side, prompting a need to understand the impact of length and cross-sectional area on heat transfer. The equation referenced, "10*A/L=T2L/A," indicates a relationship between heat transfer, area, and length, but lacks clarity without specific dimensions.
  • Understanding of Fourier's Law of Heat Conduction
  • Knowledge of thermal conductivity and its units
  • Familiarity with the concepts of heat transfer area and length in conduction
  • Basic algebraic manipulation skills for solving equations
  • Study Fourier's Law of Heat Conduction in detail
  • Research the effects of rod length and cross-sectional area on heat transfer rates
  • Explore practical examples of heat conduction in different configurations
  • Learn about thermal conductivity values for various materials
Students and professionals in physics, engineering, and materials science who are interested in understanding heat transfer principles and their applications in real-world scenarios.
goodiegrady
ok...Two identical rectangular rods of metal are welded end to end (hot dog to hot dog) with a temperature of 0 celsius on the left side and a temperature of 100 celsius on the right side. in 2 min 10 joules is conducted at a constant rate from the right side to the left side. How much time would be required to conduct 10 J if the rods were welded side to side {hamburger to hamburger}.
NO lengths mentioned which is what I am stuck on. I can get to 10*A/L=T2L/A through Q/T. K would cancel so would Q. not sure what to do with length and area as these are kind of important but not listed any ideas??
What is the basic equation you are using here? I don't see how you got to "10*A/L=T2L/A". It may be right, I just don't see how you got there.
