How can the proof by contrapositive be used to show that x^2<x implies x<1?
  • Thread starter Thread starter kathrynag
The discussion revolves around using proof by contrapositive to demonstrate that if \( x^2 < x \), then \( x < 1 \). Participants are exploring the logical structure of the proof and the implications of their assumptions regarding the values of \( x \).
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants attempt to establish the proof by assuming \( x > 1 \) and showing that \( x^2 > x \). Others question the validity of certain steps and the implications of the assumptions made, particularly regarding the equality \( x^2 = x \cdot x \) and its relevance to the proof.
The discussion is ongoing, with participants providing feedback on each other's reasoning and clarifying the logical steps involved in the proof. There is recognition of the need to correctly handle negations and assumptions, particularly regarding the conditions under which the original inequality holds.
Participants note that the inequality may not hold for all values of \( x \), particularly when \( x \) is negative. There is also mention of the necessity to assume \( x > 0 \) for the proof to be valid.
kathrynag
x^2<x, then x<1
We will use a proof by contrapositive.
We assume x>1 and we want to show x^2>x.
Let x be greater than 1 and let x^2=x*x.
If x^2=x*x, then x*x>x. Therefore, x^2>x.
Not quite, your contrapositive is correct and your first step assuming x > 1 is correct. But then you said:
Firstly x^2 = x*x is just taken for granted so you don't need to put it in. Secondly, why does x^2=x*x imply x*x > x ?
All we know is:
x > 1
Then multiplying both sides by x we get:
x*x > 1*x
so then
x^2 > x
We can also prove this without the contrapositive.
All we know is:
x > 1
x*x > 1*x
so then
x^2 > x
So, is this all I would have to do - the multiplying by x?
Think about it for a little while. Every step has to follow logically from the previous and all we had to work with was a single assumption. Search the forum for similar inequality proofs or do a Google search on introduction to proofs. If you have a textbook with a section on proofs and the different kinds, that would also help looking at.
kathrynag said:
x^2<x, then x<1
As kidmode pointed out, you can do this directly. You also need to assume that x > 0, because the inequality isn't true otherwise. E.g., if x = -1/2, x^2 = 1/4 > -1/2, and if x = -2, x^2 = 4 > -2.
Start by assuming x > 0 and that x^2 < x.
Then x^2 - x < 0.
Now factor the left side and determine which values of x make it true.
Whoops. I wrote it down but I didn't add it, thanks Mark44.
I hate to add a complication but the negation of "x< 1" is NOT "x> 1".
Whoops again.
~(x<1) = (x >= 1)
Just put a line underneath all the inequalities in your contrapositive proof lol.
You'll have to fix the negation of the right side of "if" statement.
You'll end up proving:
x^2 >= x
Thanks HallsofIvy
Well, I'm supposed to prove using the contrapositive.
"P implies Q" and "Not Q implies Not P" are logically equivalent. Constructing a truth table will show that the truth values of both statements are the same. So proving the statement is true or it's contrapositive is true are equivalent.
That wasn't clear to me from your first post "We will use a proof by contrapositive."
I interpreted that to mean that this was the direction you had decided to go, not one that was mandated in the problem.
  • · Replies 31 ·
