| Thread Closed |
Bell ringing frequency |
Share Thread | Thread Tools |
| Dec2-08, 07:55 PM | #1 |
How do I calculate the frequency of an 8.5 cm diameter bell ?
The bell is cast brass for resonance, but I intend to activate it with a buzzer so sound will last for more than a few seconds. Does the weight affect anything other than volume ? I intend to use it inverted, supported near the "top". |
| Dec3-08, 04:53 AM | #2 |
You don't.
For a real bell you would need to use numericial methods to solve the equations (unless you have a VERY simple bell, i.e. something very symmetric) but even then you are not very likely to get a useful answer, partly because real bells are note made of a "perfect" material; various imperfections etc (which in turn depends on how the bell was cast) can have quite a large influence on the resonance frequency. Is there any reason why you simply can't measure the frequency? It should be easy, all you need is a microphone connected to the sound card of a computer+some suitable software. |
| Dec3-08, 07:19 AM | #3 |
Mentor
Here is a description of what you have to do to model the sound of a bell.
"dividing the surface of the bell into a grid made of 450 squares. 'There's an equation describing the vibration of each square, and the computer can solve all the equations simultaneously,' " |
| Dec3-08, 08:24 AM | #4 |
"a traditional English-bell profile "
What I need is the "dominant strike chord" Any suggestions on "some suitable software" ? |
| Dec3-08, 09:32 AM | #5 |
Well, all you need is some software that can show you the frequency spectrum of the signal from the microphone. Sigview comes to mind and you can download a free trial version.
However, you could also try something VERY simple such as AP Tuner which is a program used to tune guitars, by default it will only show you what note you are playing (i.e. A, C# etc) but if you look n the "Recording Device and Calibration" it will also show you the last detected frequency. Or, alternatively, you could just look up what frequency e.g. C# corresponds to (chances are that a bell will be reasonably well "tuned" to a note). |
| Dec4-08, 12:06 PM | #6 |
Alternatively, you could simply listen to the note the bill produces and try to find that same note on a keyboard. Then you can look up the frequency here:
http://www.phys.unsw.edu.au/jw/notes.html or buy one of these: http://www.pas-products.com/analive.html And let it analyze the frequency for you. |
| Dec18-08, 12:28 PM | #7 |
I need piezo(?) alarms to ring my bell. I need a resonant frequencies of 392 hz and 1700 hz, 12 volts would be best. Also need a 30 minute timer.
| Thread Closed |
| Tags |
| acoustics, resonance |
| Thread Tools | |
Similar Threads for: Bell ringing frequency
| Silent Ringing Bell | Introductory Physics Homework | 7 | ||
| Phones ringing | Computing & Technology | 6 | ||
| Ringing a bell - How much energy is lost to sound? | General Physics | 10 | ||
| A ringing headache | Brain Teasers | 6 | ||
| Ramona Bell [wife of Art Bell] dead at 47 | General Discussion | 17 | ||
