Questions About Franck-Hertz Experiment
  • Thread starter Thread starter PatF
    Hertz
The discussion revolves around the Franck-Hertz experiment, focusing on understanding the setup and the significance of various components, such as the oven and thermocouple, as well as the relationship between voltage and electron volts in the context of the experiment.
  • Participants explore the purpose of the oven in vaporizing mercury and question the role of the thermocouple in affecting peak spacing at lower voltages. There is also inquiry into the relationship between volts and electron volts, particularly regarding the energy of electrons accelerated through a potential.
Some participants provide insights into the definitions and concepts related to electron volts, while others express uncertainty about specific components and their functions in the experiment. There is a mix of understanding and questions, with no explicit consensus reached.
Participants are navigating through the complexities of the experiment's setup and measurements, with some acknowledging the need for clarification on definitions and relationships between physical quantities.
PatF
I am not sure if this is the right place to post this so sorry if it is wrong. Be that as it may...
I have just completed a lab in which we do the Franck-Hertz experiment. I am trying to understand it so I have a couple of questions I hope you can help with.
1) There is an oven into which we insert a tube filled with mercury. It seems to me the only purpose of the oven is to vaporize the mercury. Is that correct?
2) The data we got seems to be fine. However, we were told that there were different spacings between the peaks because of "the thermocouple." I sort of kinda know what a thermocouple is, but why would this make a difference at lower voltages? Any ideas?
3) We got the usual data which looks like an increasing sinusoid. (Good.) We measured the distances between the peaks and we averaged about .343 volts. We performed a calibration between the measuring equipment on the computer and the electrometer and we got 14.07. (OK) If we multiply. .343 * 14.07 we get 4.82 which is close to 4.86eV which is what we are supposed to get. (Good). But 4.86 is in electron volts and the .343 is in volts. So what is the relation between volts and electron volts. Is there just a simple multiplicative factor? I am not sure this question makes sense even. It just seems like magic that we hit the correct number. I am not fond of magic and I would like to know what, if any relation there is between eV and the voltage in the experiment.
Thanks for any help of constructive criticism.
I've never actually done the experiment, so my answers may be way off.
1) That sounds right. You'd need vapour to do the experiment.
2) No idea about the thermocouple.
3) The definition of eV is that it is the energy acquired by an electron when accelerated through a potential of 1 V (hence electron-volt). In the Franck-Hertz experiment, you accelerate electrons through some voltage, say 4.9 V. Therefore the electrons would have energy ___ eV?
Naresh
"3) The definition of eV is that it is the energy acquired by an electron when accelerated through a potential of 1 V (hence electron-volt). In the Franck-Hertz experiment, you accelerate electrons through some voltage, say 4.9 V. Therefore the electrons would have energy ___ eV?"
Thanks much. That's what I needed reminding of.
you need the heat to warm the filament to liberate the electrons. If you try to keep a stable temperature, you can assume that you are releasing the same amount of electrons per unit time.
10K
