Methods of hydrogen storage on the blackboard?
  • Thread starter Thread starter Topher925
    Hydrogen Storage
The discussion centers on various methods of hydrogen storage, particularly focusing on new and upcoming technologies that could be utilized for fuel. Participants explore different storage techniques, including liquid hydrides, liquid carriers, and the potential of ethylene substances, while considering their advantages and challenges.
  • Some participants inquire about new methods of hydrogen storage beyond established techniques like hydrides, liquid hydrogen, and compressed tank storage.
  • A participant describes a method involving a liquid carrier that bonds with hydrogen, releasing it upon heating, and emphasizes the continuous recycling of the liquid.
  • Concerns are raised about the efficiency of liquid hydrides compared to solid hydrides, particularly regarding hydrogen storage capacity and extraction efficiency.
  • Another participant highlights the safety and handling advantages of liquid hydrides over solid hydrides, noting that liquids do not require pressure and are less prone to unnoticed leaks.
  • Questions arise about the rate of hydrogen dissipation from liquid in the event of a leak and the conditions under which hydrogen can be extracted from the liquid carrier.
  • A reference is made to a previous thread discussing an ethylene substance that reportedly holds 14% hydrogen by weight, which could potentially rival liquid hydrogen storage, though uncertainties remain regarding its absorption and release cycling.
Participants express a variety of viewpoints on the advantages and challenges of different hydrogen storage methods, with no consensus reached on the best approach or the feasibility of proposed solutions.
Participants note that the percentage of hydrogen mass in liquid hydrides is still under development, and there are unresolved questions about the efficiency of extraction processes and the energy requirements involved.
Topher925
I was just curious if anyone knows of any new and upcoming methods of hydrogen storage to be used for fuel. The only three methods I know about are hydrides, liquid hydrogen, and compressed tank storage. Does anyone know of any new methods that are in development? I know there's a lot of money being spent in order to solve this problem.
I saw Guido Pez present this at a symposium a few years ago.
http://www.hydrogen.energy.gov/pdfs/review05/pd34_pez.pdf
Basically, you have a 'liquid carrier' which hydrogen can be bonded to. That liquid gives up the hydrogen when heated. The hydrogen is then sent to a fuel cell and the spent liquid placed in a second storage tank. The spent liquid is then removed at the next refueling and replaced by liquid which has already had hydrogen bonded to it. In that way, the liquid is continuously recycled.
Very interesting, I never even knew liquid hydrides even existed. But what advantage does a liquid hydride provide over a conventional solid hydride besides the form of the fuel tank? Mn if I remember correctly can store up to 11 wt.% while the liquid hydride in that proposal can only store 6 wt.%. Is it easier or more efficient to extract the H2?
Good question. The primary advantage is safety and secondarily is the ease of handling. Liquid is both safer and easier to handle. Solid hydrides require some amount of pressure and require gasseous storage at the point of delivery. Liquids don't require any pressure and allow liquid delivery. H2 gas can leak easily and without being noticed and can even burn without producing a visible flame. Liquid leakage is less likely because of the lower pressure and higher molecular weight. Also, liquid won't burn without producing a visible flame. Note also the percentage of H2 mass is all still in development, so the 6% might be increased in the near future.
That makes a lot of sense. If there was a leak at STP at about what rate would the H2 dissipate from the liquid? Your link has data for extraction at 190C+ under pressure but would the H2 sort of "extract" if there was a liquid leak from the storage tank?
If someone were to get develop a safe, cheap, and readily available liquid hydride with a ~50 wt% that would change everything. Although I would imagine there would still be a lot of issues with cold start up which is an issue that compressed H2 does not have.
Chemisttree started this thread last year, referencing a Chemistry World article on a discovery that an ethylene substance would hold 14% H by weight, or about double what hydrides will do.
https://www.physicsforums.com/showpost.php?p=1540473&postcount=1"
If if works out, then by this http://www.rsc.org/chemistryworld/Issues/2007/October/HydrogenStorageTargetsOutOfReach.asp" ethylene becomes gravimetrically and volumetrically comparable with liquid hydrogren storage (10% H by weight), a big win. No results yet on absorption/release cycling, nor any mention of energy required in cycle, which is the problem with liquid H.
The page in the presentation regarding 190 C temperature and "hydrogenation" at 1000 psi regards the process of taking the 'empty' liquid and putting hydrogen into it. That process is done at the plant. So under elevated temperature and pressure, the liquid is hydrogenated. Once the hydrogen has been 'put in' and the temperature brought back down to ambient, the hydrogen can't come back out. You could have it sitting in an open cup and no hydrogen would break free from the carrier. In order to have the hydrogen separate from the carrier liquid, heat must be applied. Note also that a catalyst is used for both hydrogenation and dehydrogenation as indicated on sheet 4 of the presentation. Sheet 12 of the presentation shows rates of dehydrogenation given various temperatures and the overall conversion rate. Conversion rate is the percent of hydrogen removed from the liquid carrier.
  • · Replies 18 ·
