Finding velocity of a falling object
The problem involves determining the time it takes for a ball to hit the ground when dropped from a height, as well as its velocity just before impact. The height function is given, and participants are exploring the implications of this function in the context of kinematics.
  • Participants discuss the calculation of time until impact and the corresponding velocity. There is confusion around the use of limits and derivatives, with some questioning the need for limits when evaluating velocity at the time of impact.
Participants are actively engaging with the problem, offering guidance on evaluating the velocity function at the calculated time of impact. There is recognition of misunderstandings regarding the interpretation of velocity at the moment of impact versus just before it.
There is an ongoing discussion about the validity of the height function and its implications for the behavior of the ball as time progresses. Some participants note the constraints of the function, particularly when height becomes negative.
psyklon
When Mongol drops his ball off the Hasselbluff Mountain Viewpoint, its height above the ground at time t is given by h = 64 - 1/2gt2. How long will the ball take to hit the ground? How fast is the ball going the instant before it hits the ground?
I found the answer to the first question to be: t = 8√2/√g
The derivative is v(t) = - gt
v(t) = [lim t-->0] - g(8√2/√g + ∆t) - - g(8√2/√g)
v(t) = [lim t-->0] - g8√2/√g + g(8√2/√g)
v(t) = [lim t-->0] 0
:confused: I know that I'm doing something very obviously wrong, I just can't figure out what.
You already found v(t), so why not just evaluate [tex]v \left( \frac{8\sqrt{2}}{\sqrt{g}} \right)[/tex]?
It looks like you are trying to find acceleration with that limit, but incorrectly.
You said v(t)=-gt. Very true. Why don't you just use that? What's this limit stuff all about?
Well my reasoning was that since it hit the ground at t = 8√2/√g. I would have to put a limit on t to make it very, very close to that but not equal to it since then it would have already hit the ground. I suppose for what I was going for, the limit would have been 8√2/√g.
So what time would I insert into the equation v(t)=-gt?
Put in the time it hits the ground!?? You want to know how fast it's going 'when it hits the ground'. The time you just figured out. You do know that v(t) is the velocity at time=t, right?
I want to find the velocity the instant before it hits the ground. I guess I'm misunderstanding the question and I should be finding it for t = 8√2/√g and not trying to figure out how to express a value for time that's an instant before.
So, plugging it into the equation I get:
v(t) = - g(8√2/√g)
v(t) = - 8g√2/√g
v(t) = - 8(9.8)√2/√(9.8)
v(t) ~ -35.42
...which is definitely the correct answer. :biggrin: Thank you so much Dick and mutton! My misunderstanding definitely came from thinking that if I put in the time at which it hit the ground, the result for velocity would be zero. Why doesn't this happen? :confused:
That's a question for philosophers. When it is "on" the ground it's velocity is zero. An instant before it hits the ground, it's exactly what you computed. That's what they are after.
It's implied that the given function h is valid only when t [tex]\ge[/tex] 0 and h [tex]\ge[/tex] 0. Notice that h < 0 for t > 8√2/√g, which would mean the ball goes underground.
So what you found is a limit; it is the limit of v as t approaches 8√2/√g, because v is really 0 when t = 8√2/√g. "The instant before it hits the ground" isn't just any instant; this wording let's you describe what happens if the ball were to keep falling.
Oh wow! Got it! Thanks again you two, you've been a great help. :blushing:
  • · Replies 17 ·
  • · Replies 38 ·
9K
