Solving Multi-Spring System for Node4
  • Context: Undergrad
  • Thread starter Thread starter themiddle
    System
The discussion revolves around determining the coordinates of a movable node (node4) in a multi-spring system connected to three fixed nodes in a 2D coordinate system. Participants explore various methods to achieve equilibrium in the system, focusing on the balance of spring forces and potential energy minimization.
  • One participant suggests that the rest lengths and maximum extensions of the springs are necessary for a complete understanding of the system.
  • Another participant proposes using virtual springs that extend from zero to infinity to simplify the problem.
  • A participant expresses the intention to write an algorithm to approximate the coordinates of node4, but is unsure about setting up the necessary equations.
  • One participant mentions two unsatisfactory approaches: using an algorithm that lacks a general formula and considering a method to simplify the problem into 1-dimensional problems by disconnecting springs.
  • Another participant shares a specific example where, for equal spring constants, node4's coordinates can be approximated, but notes the difficulty in expressing these coordinates in terms of the spring constants.
  • One suggestion involves minimizing potential energy as a method to find the coordinates of node4, proposing a quadratic function based on the spring constants and positions of the fixed nodes.
  • Another participant agrees with the potential energy minimization approach and provides a detailed algebraic formulation for equating forces to zero along the x and y axes.
Participants express various methods and approaches to solve the problem, but no consensus is reached on a definitive solution or method. Multiple competing views remain regarding the best approach to determine the coordinates of node4.
Some limitations include the dependence on the definitions of spring constants and the potential need for additional parameters such as rest lengths. The discussion also highlights the complexity of deriving a general solution versus using numerical approximations.
themiddle
Hi all,
I'm having some trouble understanding a multi-spring system.
Say I have 3 fixed nodes located at the following points in a 2D coordinate system:
node1: (2,4)
node2: (12,18)
node3: (30,6)
I have another node, node4, that is not fixed.
Then I connect node4 to all three fixed nodes using springs. The spring constants are as follows.
node4-node1: k1
node4-node2: k2
node4-node3: k3
My end goal is to determine the placement (coordinates) of node4, such that all the spring forces balance. i.e.
F_total = 0 = F1_4 + F2_4 + F3_4
How can I go about solving (or approximating) for the (x,y) coordinates of node4 such that the forces (or energy) of the system sums to zero?
Wouldn't you also need to know the rest lengths of the three springs and their respective maximum extensions? Or are we dealing with virtual springs which extend from 0 to infinity?
Yes, I'm hoping to use virtual springs that extend from zero to infinity.
I'm going to write an algorithm to approximate suitable (x,y) coordinates for node4 that result in equilibrium, but at this point I'm still trying to figure out how to set up the equation.
That is an interesting problem you have set yourself. I don't have much time to think about it at this moment but if the question is still unresolved by the time I get home then I'll take a proper look.
Thank you very much, any help would be greatly appreciated.
Just letting you know that I haven't forgotten about your question -- it is just that it is rather advanced for the likes of me. Having given up on solving algebraically, I have at the moment only two lines of thought, but both unsatisfactory.
My first instinct was to cheat by writing a simple algorithm which will rapidly home in on the coordinates of node4, for given values of k1, k2 and k3. The problem with this method is that it does not provide a general formula for the coordinates of node4, but instead must be re-run from scratch whenever you change any of the spring constants or node coordinates. Furthermore, while this method would provide a solution, it would not increase our understanding of how the solution was arrived at.
My second thought is that there might be a way of simplifying your 2-dimensional problem into a set of (easy) 1-dimensional problems, and then using these to somehow find the coordinates of node4. Clutching at straws, I wondered what would happen if you disconnected one of the springs (say, spring 3) from node4, allowing springs 1 & 2 to come to rest, then noted the centre-point between them; and then repeated the process for springs 1 and 2...as pictured below...would the centre-point of the new triangle (in red) be the location of node4? That is pure conjecture, though. I have no supporting proof other than that it "feels like node4 should be there". The following diagram shows the symmetrical case of an equilateral triangle with k1 = k2 = k3.
http://tinyurl.com/6qz3dl
I'll work on the algorithm for the time being. Wish I could have been of help!
Well, I have a short program set up to find your node4 coordinates. If you have specific values of k1, k2 and k3 in mind then you're in luck; the coordinates of node4 can be found. For example, when k1 = k2 = k3 = 1, node4 lies very close to (12.81, 12.69). If you want node4's coordinates in terms of k1, k2 and k3, however, then I can't help you. Somebody else ought to be able to, though.
- m.e.t.a.
P.S. This disproves my guess that node4 might be found by drawing a kind of triangle. But then, it was quite a random guess.
Instead of messing with forces, you could try minimizing the potential energy. Specifically:
Given positions x1, x2, and x3 and spring constants k1, k2, and k3, you try and find x such that the quantity V = (k1|x - x1|2 + k2|x - x2|2 + k3|x - x3|2)/2 is minimized. You should be able to do this algebraically, since V is just a quadratic function of the coordinates of x.
Adriank: yes, that sounds a lot more sensible.
You don't have to do that actually, you can simply equate the sum of the forces to zero along the x and y axes.
[tex]F_1=k_1\left(\left(\begin{array}{c}2\\4\end{array}\right)-\left(\begin{array}{c}x\\y\end{array}\right)\right)=\left(\begin{array}{c}2k_1-k_1x\\4k_1-k_1y\end{array}\right)[/tex]
[tex]F_2=k_2\left(\left(\begin{array}{c}12\\18\end{array}\right)-\left(\begin{array}{c}x\\y\end{array}\right)\right)=\left(\begin{array}{c}12k_2-k_2x\\18k_2-k_2y\end{array}\right)[/tex]
[tex]F_3=k_3\left(\left(\begin{array}{c}30\\6\end{array}\right)-\left(\begin{array}{c}x\\y\end{array}\right)\right)=\left(\begin{array}{c}30k_3-k_3x\\6k_3-k_3y\end{array}\right)[/tex]
[tex]F_{tot}=\left(\begin{array}{c}2k_1+12k_2+30k_3-(k_1+k_2+k_3)x\\4k_1+18k_2+6k_3-(k_1+k_2+k_3)y\end{array}\right)=0[/tex]
[tex]\implies x=\frac{2k_1+12k_2+30k_3}{k_1+k_2+k_3}\mbox{, }y=\frac{4k_1+18k_2+6k_3}{k_1+k_2+k_3}[/tex]
  • · Replies 24 ·
12K
