Is (2n-1)! Always a Square Modulo 2n+1?
  • Context: Graduate
  • Thread starter Thread starter killerinstinct
    Arithmetic
The discussion revolves around whether the factorial of (2n-1) is always a square modulo (2n+1). Participants explore this question through different cases based on the primality of (2n+1) and invoke concepts such as Wilson's theorem and the Legendre symbol.
  • Some participants propose that for non-prime (2n+1), every prime factor must be contained in (2n-1)!, leading to a remainder of zero, which is a perfect square.
  • Others argue that if (2n+1) is prime, Wilson's theorem implies that (2n-1)! is congruent to 1 modulo (2n+1), also a perfect square.
  • A later reply questions the initial claim regarding non-repeated prime factors, suggesting that repeated prime factors require a different argument to show that (2n-1)! has sufficient factors to cover them.
  • Some participants express uncertainty about the Legendre symbol and its relevance to the modular question at hand.
Participants present multiple competing views regarding the cases of primality and the implications for the factorial's properties modulo (2n+1). The discussion remains unresolved with no consensus reached.
Limitations include assumptions about the nature of prime factors and the specific cases considered, as well as the dependence on definitions related to the Legendre symbol and Wilson's theorem.
Readers interested in number theory, particularly in modular arithmetic and properties of factorials, may find this discussion relevant.
killerinstinct
Show that (2n-1)! is always a square modulo 2n+1.
:cry:
Mathematics news on Phys.org
what do you know about legendre's symbol?
I'd treat it as two separate cases.
Case 1: (2n+1) is non-prime.
In this case it is easy show that every prime factor of (2n+1) must be contained in (2n-1)! and hence the remainder is zero (a perfect square).
Case 2: (2n+1) is prime.
Let prime p = (2n+1).
By Wilson's Thm (see link), (p-1)! = (p-1) : modulo p
(p-2)!(p-1) = (p-1) : mod p
(p-2)! = 1 : mod p
Hence the remainder is always 1 (a perfect square) for this case.
In summary the remainder is always zero when (2n+1) is non-prime and is always one when (2n+1) is prime.
Link for Wilsons Thm
Quick errata :
In case 1 when I said, "it is easy show that every prime factor...", I have to admit that I was thinking specifically about non-repeated prime factors at the time, in which case the result really is trivial enough to be done "by inspection".
For the case where (2n+1) has repeated prime factors like q^m then you can use an argument along the lines of :
Assume (2n+1) has a prime factor of the form q^m, where q is prime >= 3 and m is integer >= 2.
BTW. Note that (2n+1) can't have 2 as a factor so we only need to look a 3 and greater. Also, since I'm looking specifically at the case of repeated factors I only need to consider m greater or equal to 2.
Since q^m is a factor then,
(2n+1) >= q^m
(2n-1) >= q^m - 2
But also it is easy to show that q^m - 2 > m*q for q>=3 and m>=2
Loosly what this means is that if (2n+1) has a repeated prime factor q^m then (2n-1)! has enough factors of the form q, 2q, 3q etc to "cover" it.
Legendre symbol? Heard of, but not know much about it. It could possibly explain this modular question?
thanks to uark for a detailed and well-given solution!
