Where can I find the coefficient of resistance for different metals?
  • Thread starter Thread starter langt
    Properties
The discussion revolves around finding reliable sources for the coefficient of resistance (temperature coefficient of resistance, TCR) for various metals. Participants share their experiences and resources related to this topic, which is relevant to material properties in physics and engineering.
  • One participant seeks a comprehensive source for the coefficient of resistance of metals, specifically asking if there are metals with a TCR larger than that of nickel (0.005866).
  • Another participant notes that nickel has one of the highest TCR values among common elements, similar to iron and cobalt, and provides a link to a resource listing these values.
  • A third participant shares multiple links to websites that contain resistivity values, reiterating the initial query about finding TCR values.
  • One participant comments on the variability of resistance values across different lists, attributing this to the sensitivity of resistivity to sample purity, while noting the consistency of platinum values due to its characterization and purity.
Participants express a shared interest in finding accurate TCR values, but there is no consensus on a single reliable source, and the variability in reported values suggests ongoing uncertainty in the discussion.
The discussion highlights limitations in the availability of consistent data and the influence of sample purity on resistivity measurements, which may affect the reliability of the sources provided.
langt
Does anyone know a website that I can get coefficient of resistance of metals?
I've been searching for 2 weeks and have yet to get more than a few basic material readings, "alpha" per degree Celsius. (example) Nickel 0.005866 is there any metal larger than that number?
Nickel's TCR is the largest I've seen on a list of about twenty-five common elements. The value is similar for the other elements in that group, iron and cobalt. Most other metals are lower, around 0.4%/K.
The list came from http://www.tf.uni-kiel.de/matwis/amat/elmat_en/kap_2/illustr/t2_1_1.html" .
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/rstiv.html
http://en.wikipedia.org/wiki/Resistivity#Table_of_resistivities
http://www2.latech.edu/~rselmic/Courses/ENGR221/Additional%20Material/Resistivity%20Values%20for%20Selected%20Materials.pdf
CS
It's striking how much the values differ between the multiple lists, though the order of magnitude is the same. A reminder of how exquisitely sensitive resistivity is to sample purity. Note the good agreement, though, for platinum, due to both extensive characterization as a temperature sensor (in RTDs) along with limited impurity incorporation into a noble metal.
  • · Replies 21 ·
10K
