Physics Dynamics: Angular and Linear Motion of Machine Components
  • Thread starter Thread starter tom23
    Dynamics Physics
The discussion revolves around the dynamics of a machine involving angular and linear motion, specifically focusing on the acceleration and velocity of gears and a rack. The original poster seeks assistance in determining the angular velocity and acceleration of gear A, as well as the linear acceleration and velocity of rack C, based on the acceleration of gear B.
  • Exploratory, Assumption checking
  • Participants discuss the calculations for angular velocity and acceleration of gear B, and subsequently for gear A. There are questions about the distances between the teeth on the gears and how that affects the calculations. The original poster attempts to derive linear velocity and acceleration for rack C based on the results for gear A.
Participants are actively engaging in calculations and verifying each other's work. Some guidance has been provided regarding the relationship between the gears and the rack, and there is a recognition of the need for consistent tooth spacing to validate the calculations. Multiple interpretations of the problem setup are being explored.
There is uncertainty regarding the distance between the teeth on gears B, A, and C, which affects the calculations. The original poster notes that this information was not provided, leading to assumptions about uniformity in tooth spacing.
tom23
Gear ‘B’ on the machine shown below accelerates from rest to 250 rpm in 2 seconds. Determine the angular velocity and acceleration of A, and the linear acceleration and velocity of rack C. See image attached
I don't know where i would start off with this question, help would be appreciated.
Welcome to PF!
Hi tom23! Welcome to PF!:smile:
(how far apart are the teeth on B compared with A and C? :confused:)
First find the angular velocity and acceleration of B.
Then you know that the "tooth-rates" on A B and C are the same … eg if B rotates through 7 teeth of the cog, then both A and C also move through 7 teeth. :wink:
So I got this until now, is it right?
ang velocity = 250 rpm x 2 pi x (1/60) = 26.2 rad/s
ang acceleration = change in ang velocity / chang in time = 26.2 rad/s / 2s = 13.1 rad/s^2
Thus at B: tangential Velocity at B = ang velocity*radius1 = 26.2*20 = 524 cm/s
tangential Acceleration at B = ang acceler.*radius1 = 13.1*20 = 262 cm/s^2
Therefore on A:
Angul. Velocity at A = tang. velocity/radius2 = 524/15 = 34.9 rad/s
Angul. Acceler at A = tang. acceler./radius2 = 262/15 = 17.5 rad/s
Does this two answers sound right, now how would i go on to solve for linear accel. and velocity of rack C?
Yes, that's fine. :smile:
Therefore on A:
You haven't answered my question: how far apart are the teeth on B compared with A and C?
If they're the same distance apart, then your answer is right.
Same method … you have the tangential velocity of A, so you can find the linear velocity of C.
Tey didnt give the distance, so i believe it is the same, so for linear velocit and accel at C, i got:
V = 34.9 (30cm) = 1047 cm/s
a = 17.5 (30cm) = 525 cm/s
Does it look right?
Thanlks for all your help above!
Hi tom23! :smile:
Does it look right?
Yes … that's fine … if the teeth are all the same distance apart, then the tangential velocities and the linear velocity are all the same. :smile:
(though I'd have done it directly from B … 26.2(40), rather than from A, as you did! :wink:)
  • · Replies 47 ·
  • · Replies 33 ·
  • · Replies 98 ·
  • · Replies 45 ·
  • · Replies 17 ·
