Integrability of g, Nonnegativity & Infinite Points: Is it True?
  • Context: Graduate
  • Thread starter Thread starter kala
The discussion revolves around the integrability of a function g that is nonnegative on the interval [a,b] and the implications of g being greater than or equal to zero at an infinite number of points within that interval. Participants explore whether this leads to the conclusion that the integral of g over [a,b] is greater than zero.
  • Some participants question whether the statement is true, suggesting that if g is integrable and nonnegative on [a,b], then having g(x) ≥ 0 for an infinite number of points should imply that the integral \int g > 0.
  • One participant provides a counterexample where g is positive at only a finite number of points, arguing that this does not contradict the integrability condition.
  • Another participant presents a different counterexample, where g is defined to be 1 at points of the form 1/n and 0 elsewhere, showing that it can be integrable with an integral of zero despite being positive at infinitely many points.
  • A further example is introduced involving a function that takes on positive and negative values at rational and irrational points, respectively, leading to a negative integral, which raises questions about the assumptions regarding nonnegativity.
  • Some participants highlight the ambiguity in the type of integrability being discussed, with references to both Riemann and Lebesgue integrals, suggesting that the context may affect the validity of the claims made.
  • One participant suggests that if the statement is modified to \int^b_a g(x) \ge 0, it could be considered true, but others find this trivial or not directly addressing the original problem.
  • There is a discussion about the implications of modifying functions to ensure nonnegativity while retaining integrability, with some arguing that such modifications do not resolve the original question.
Participants express differing views on the validity of the original statement, with some providing counterexamples that challenge its truth. The discussion remains unresolved, with multiple competing perspectives on the implications of the conditions stated.
Participants note the importance of clarifying the type of integrability being referenced (Riemann vs. Lebesgue) and the implications of nonnegativity in the context of the integral. There are also discussions about the nature of discontinuities and the measure of sets involved in the examples provided.
kala
I can't make up my mind if this statement is true or not: is it true that if we assume g is integrable and g[tex]\geq[/tex]0 on [a,b], then if g(x)[tex]\geq[/tex]0 for an infinite number of points x is in [a,b] then [tex]\int[/tex] g >0.
I can't figure out if its true or false, i thought that i had a counter example:
if g>0 at a single point i.e. g(a)=1 and g=0 otherwise, then g is integrable and non negative, and the set of discontinuities must be finite.
I don't know if this is exactly right. Any help please?
What do you mean with g(x)>0 for an infinite number of points x in [a,b]? Are u saying here, that we are assuming that for some points in [a,b] g(x) might not be greater than 0 or?
I'm assuming you mean if on [a, b], g is integrable and nonnegative, and g(x) > 0 for an infinite number of points x in [a, b], then [tex]\int_{[a, b]} g > 0[/tex].
Your example only has g(x) > 0 for a finite number of points, so it is not a counterexample.
However, here is a counterexample: On [0, 1], let g(x) = 1 if x = 1/n for some positive integer n, and 0 otherwise. Then g(x) = 1 at infinitely many points, but it is integrable and the integral is zero. Reason: each point in S = {1/n | n is a positive integer} is an isolated point of S.
No, it is not true. For example, if f(x)= 1 for x rational and f(x)= -1 for x irrational, then f(x) is "positive for an infinite number of points" but its (Lebesque) integral, from x=0 to x=1, is -1 since f(x)= -1 except on a set of measure 0.
Two issues I have with that argument: First, it doesn't directly address the problem, since there is the assumption that g(x) ≥ 0 everywhere. Second, he didn't specify which kind of integrability we're talking about, so I just assumed we're talking about Riemann-integrable functions, and yours is not one of them.
The statement is true if you make it [tex]\int^b_ag(x) \ge 0[/tex]
To see this evaluate the integral with Riemann sums and we make the distance between each point of subdivision equal. So let [tex]h = \frac{b-a}{n}[/tex]. Then we have [tex]\int^b_ag(x) = \lim_{n \rightarrow \infty} \sum\limits_{i=1}^n h(g(x_i))[/tex]
The sum is greater than or equal to zero because each term in the sum is nonnegative.
Yes, but that's trivial.
It was similar to what the OP was asking. There is no harm done in adding what I added.
You can easily make HallsOfIvy's function nonnegative, just make it 0 at every irrational number. Come on, you could make that small modification.
You could, and the (Lebesgue) integral would be zero. However, that is not Riemann integrable (which is what I was assuming).
Well, working in this situation with the Riemann integral is rather delicate, because even the integrability of such a function is difficult to establish. Sorry if you meant Riemann, I just always think Lebesgue.
I think what I was really trying to say was that the statement is false even for Riemann-integrable functions, nothing more.
  • · Replies 30 ·
