Parametrizing a Cylinder: Solving for the Part Between Two Planes
  • Thread starter Thread starter hils0005
    Cylinder
The problem involves parametrizing a section of the cylinder defined by the equation 4y² + z² = 36, specifically the part located between the planes x = -3 and x = 7.
  • Participants discuss the correct parametrization of the cylinder, with initial attempts involving incorrect assumptions about the radius and the nature of the cross-section. Questions arise regarding the implications of the factor of 4 in the equation and how it affects the parametrization.
Some participants have provided guidance on correcting the parametrization by addressing the factor of 4 and suggesting transformations. There is an ongoing exploration of the correct forms for y and z, with some participants questioning the need to specify the range for theta.
Participants are navigating the constraints imposed by the original problem statement, particularly the non-circular cross-section of the cylinder and the implications for parametrization.
hils0005
Parametrize the part of the cylinder 4y^2 + z^2 = 36 between the planes x= -3 and x=7
radius=6
Parametric equations:
x=x
y=4 + 6cos(theta)
z=6sin(theta)
in vector form
[tex]\widehat{}r[/tex]= x[tex]\widehat{}i[/tex] + (4 + 6cos(theta))[tex]\widehat{}j[/tex] + 6sin(theta)[tex]\widehat{}k[/tex]
-3 [tex]\leq[/tex] x [tex]\leq[/tex] 7
I really don't know if I'm completing correctly, any direction would be appreciated. Thanks!
radius=6
x=x
y=4 + 6cos(theta)
z=6sin(theta)
These y,z do NOT satisfy 4y^2+z^2=36. Moreover, you cannot speak of a radius here, as the crosssection of the cylinder is not a circle.
the cross sections of the cylinder perpendicular to the x-axis are circles y^2 + z^2=6^2 correct?
then this would be given parametrically as y=6cos(theta) and z=6sin(theta) right?
This is correct, but in your original problem the y^2 is multiplied by a factor 4.
If you let y'=2y, then you have
y'^2+z^2=36 and so
y'=6 cos(theta)
z =6 sin(theta)
Now use y=y'/2 and you're done.
Thanks I did not know what to do with factor of 4
so would this be correct?
x=x
y=3cos(theta)
z=6sin(theta)
in vector form
[tex]\widehat{}r[/tex]= x[tex]\widehat{}i[/tex] + 3cos(theta)[tex]\widehat{}j[/tex] + 6sin(theta)[tex]\widehat{}k[/tex]
do i need to say anything about theta going from 0 to 2pi?
