| Thread Closed |
Find the depth of a tube submerged in water that is half filled with air |
Share Thread |
| Dec5-08, 05:52 PM | #1 |
A tube of length L = 25 m that is open at one end contains air at atmospheric pressure. This is done in Denver so atmospheric pressure P = .667 X (1.10 X 105 Pa). The tube is thrust vertically into a freshwater lake until water rises halfway up in the pipe. Find the depth of the tube in the water. Note: air can be treated as an ideal gas. In the attachment there is a picture on problem #5. The picture will really help clarify the problem. 2. Relevant equations P = P(initial) + [tex]\rho[/tex]gd [tex]\Sigma[/tex]F = ma P=F/A 3. The attempt at a solution I know the pressure of the air inside the tube and I also know that the forces exerted by the air and the water are the same but I am just not sure how to tie all of these things together to find the depth. |
| Dec5-08, 06:07 PM | #2 |
Mentor
Hint: What's the pressure of the compressed air in the tube?
| Dec5-08, 06:15 PM | #3 |
Isn't it equal to the atmospheric pressure?
| Dec5-08, 06:25 PM | #4 |
Mentor
| Dec5-08, 06:59 PM | #5 |
By putting it in the water the volume was halved so the pressure is the atmospheric pressure divided by 2?
| Dec5-08, 07:08 PM | #6 |
Mentor
| Dec5-08, 07:20 PM | #7 |
But I don't know the volume or the number of moles either.
| Dec5-08, 07:27 PM | #8 |
Mentor
| Dec5-08, 07:49 PM | #9 |
Ok so I solved for pressure now can I use this in the formula P = P(initial) + [tex]\rho[/tex]gd but I am not sure if that will work.
| Thread Closed |
Similar discussions for: Find the depth of a tube submerged in water that is half filled with air
| [SOLVED] Calaculate Mass of Cube submerged in oil and water | Introductory Physics Homework | 6 | ||
| Why is a half-filled test tube considered an open pipe? | Introductory Physics Homework | 0 | ||
| Why do atoms prefer filled, half filled, or empty shells?? | Atomic, Solid State, Comp. Physics | 1 | ||
| Pressure In A Submerged Tube | Introductory Physics Homework | 2 | ||
