Slit diffraction with a beam of spatially distributed intensity
The discussion focuses on the slit diffraction experiment involving light incident on two narrow slits, where the light intensity is spatially distributed rather than uniform. The participant attempts to derive the electric field equation for the diffracted light, starting with a summation of electric fields and expressing it in terms of complex exponentials. The challenge lies in simplifying the expression to a form involving sines and cosines, as well as graphing the resulting distribution pattern. Key insights include the necessity of taking the real part of the result to obtain a sum of sine and cosine products.
  • Understanding of wave optics principles, specifically diffraction.
  • Familiarity with complex numbers and Euler's formula.
  • Knowledge of trigonometric identities and their application in wave equations.
  • Experience with graphing software capable of handling complex functions.
  • Explore the derivation of the electric field in multi-slit diffraction using complex exponentials.
  • Learn how to apply trigonometric identities to simplify complex wave equations.
  • Investigate graphing tools that support complex number visualization, such as MATLAB or Python's Matplotlib.
  • Study the real part of complex wave functions to understand physical interpretations in diffraction patterns.
Students and researchers in physics, particularly those studying wave optics, as well as anyone interested in advanced mathematical techniques for analyzing diffraction patterns.
shyree
I have the classic slit-diffraction experiment, where light is incident on two narrow slits on a screen and is diffracted to create a pattern of maxima and minima on the far surface. It is usually assumed that the light incident on the slits is uniform. In practice, the light generally varies a little bit, i.e. you have a spatial distribution of intensity rather than one intensity, so the intensity of the incident light through each slit is a little bit different.
I started by summing the diffracted bits of electric field:
E = E(0)e^i(kr - wt) + E(0)e^i(k(r + dsin(theta)) - wt) + E(0)e^i(k(r + 2dsin(theta)) - wt)...
If all the E(0)'s are the same, they can be pulled out from the exponential, and then the exponential can be summed alone and a trig identity used to change it into an equation with sines instead of e^1(thing)'s. If they're all different...
E = Ae^i(kr - wt) + Be^i(k(r + dsin(theta)) - wt) + Ce^i(k(r + (N-1)dsin(theta)) - wt)
let (phi) = kdsin(theta)
E = e^i(kr - wt)*(A + Be^i(phi) + Ce^i2(phi))
and I can't get it to simplify any more than that. Is there a way to get this into a form with sines and cosines? Failing that, is there a way to graph this as-is to get the distribution pattern? I haven't been able to find any graphing software that'll play nice with e^i factors.
Don't you need to make those r's into (r-r0)'s (vectorwise)? You refer to a 2-slit problem in your problem statement, but in your solution you are dealing with multiple slits. You should take the real part of the result, which will be a sum of products of sines and cosines.
  • · Replies 20 ·
  • · Replies 17 ·
