Mobius Inversion, finite subgroup
The discussion centers on the proof that a finite subgroup G of the multiplicative group of a field F, denoted as F^*, is cyclic. It establishes that if |G|=n, then for any divisor d of n, the polynomial x^d-1 divides x^n-1 in F[x], confirming that x^d-1 has d distinct roots in G. The discussion also clarifies the relationship between the number of elements of G with a specific order, represented by the function ψ(k), and the Euler φ-function, leading to the conclusion that ψ(n)=φ(n) through Möbius inversion, thereby proving G is cyclic.
  • Understanding of finite groups and cyclic groups
  • Familiarity with polynomial factorization in F[x]
  • Knowledge of the Euler φ-function and its properties
  • Concept of Möbius inversion in number theory
  • Study the properties of cyclotomic polynomials and their applications
  • Learn about the structure of finite groups and their classification
  • Explore the Möbius inversion formula in detail
  • Investigate the relationship between group orders and element orders in finite groups
Mathematicians, particularly those specializing in group theory, algebra, and number theory, as well as students seeking to deepen their understanding of finite groups and cyclic structures.
mathsss2
The parts of this problem form a proof of the fact that if [tex]G[/tex] is a finite subgroup of [tex]F^*[/tex], where [tex]F[/tex] is a field (even if [tex]F[/tex] is infinite), then [tex]G[/tex] cyclic. Assume [tex]|G|=n[/tex].
(a) If [tex]d[/tex] divides [tex]n[/tex], show [tex]x^d-1[/tex] divides [tex]x^n-1[/tex] in [tex]F[x][/tex], and explain why [tex]x^d-1[/tex] has [tex]d[/tex] distinct roots in [tex]G[/tex].
(b) For any [tex]k[/tex] let [tex]\psi(k)[/tex] be the number of elements of [tex]G[/tex] having order [tex]k[/tex]. Explain why [tex]\sum_{c|d}\psi(c)=d=\sum_{c|d}\phi(c)[/tex], where [tex]\phi[/tex] is the Euler [tex]\phi[/tex]-function.
(c) Use Mobius Inversion to conclude [tex]\psi(n)=\phi(n)[/tex]. Why does this tell us [tex]G[/tex] is cyclic?
Here is what I have so far:
a) The first part is trivial [[tex]y - 1[/tex] divides [tex]y^k - 1[/tex], there values of [tex]y[/tex] and [tex]k[/tex] will give us our result - I need to show this]. If [tex]|G| = n[/tex] then the roots of [tex]x^n - 1[/tex] are precisely the elements of [tex]G[/tex], which are distinct. (Note how strong this result is. Specifying the order of [tex]G[/tex] specifies [tex]G[/tex] uniquely.) Since the roots of [tex]x^d - 1[/tex] are a subset of the roots of [tex]x^n - 1[/tex], they must also consist of [tex]d[/tex] distinct elements of [tex]G[/tex].
b) [tex]\sum_{c | d} \psi(c)[/tex] is the number of elements having order dividing [tex]d[/tex], and those are precisely the roots of [tex]x^d - 1[/tex]. On the other hand, [tex]x^d - 1 = \prod_{c | d} \Phi_c(x)[/tex] where [tex]\text{deg } \Phi_c = \phi(c)[/tex].
c) The first part is trivial [we use Möbius inversion to uniquely extract the value of [tex]\psi[/tex] from the equation. But the equation is the same for [tex]\phi[/tex]]. Since [tex]\psi(n) > 0[/tex], [tex]G[/tex] has elements of order exactly [tex]n[/tex].
I am still confused on all of the parts. I am not sure if I am doing this right. Any ideas/comments would be great.
Hi!
I can not help you with the part of $\psi$ function but yes with the other part.
It is well known that
[tex]x^{n}-1=\prod_{d|n}\Phi_d(x),[/tex] where [tex]\Phi_d[/tex] is the dth-ciclotomic polynomial which has degree [tex]\phi(d)[/tex], in other words, the euler function of d, so know (a) should be striagtforward. Because if d divides n, then each divisor of d is a divisor of n.
(b) Is a fact of degrees, so is by definition.
I suggest to read the info about ciclotomic polynomial at wikipedia or www.mathworld.com
  • · Replies 26 ·
  • · Replies 25 ·
