Bicycle gears, energy, work and power?
When shifting to a lower gear on a bicycle while maintaining the same pedaling rate, the power output remains constant despite changes in torque and speed. Lowering the gear ratio from 1:1 to 2:1 results in a reduction of output speed to half, while torque doubles. This adjustment allows for better matching of the available power to the required work of moving the bicycle uphill. Ultimately, gear changes do not increase or decrease power; they merely alter the relationship between torque and speed.
  • Understanding of mechanical power and torque concepts
  • Familiarity with bicycle gearing systems and ratios
  • Basic knowledge of work-energy principles
  • Experience with pedal cadence and its effects on cycling performance
  • Research bicycle gear ratios and their impact on cycling efficiency
  • Explore the relationship between torque and power in mechanical systems
  • Learn about the physics of work done against gravity in cycling
  • Investigate optimal gear shifting techniques for various terrains
Cyclists, mechanical engineers, and fitness enthusiasts interested in optimizing cycling performance and understanding the mechanics of bicycle gearing.
many_atoms
Bicycle gears, energy, work and power??
hi everyone,
let's say you're riding a bicycle, and as you approach a hill, you shift to a lower gear. You pedal at the same rate, however. Does the power increase, decrease or stay the same? An explanation would be helpful. I've been trying to reason through this all day. I know that changing to a lower gear increases the amount of power, but what about the case of pedaling at the same rate?
Thanks!
There should not be an increase in power because of the gear shift. You will be doing work because of the hill, but you'll be going slower. If you were to find the exact right gear, power would remain constant.
Changes made by gearing are conversions of mechanical output speed verses mechanical input speed. When you shift to a lower gear (for instance, drop from 1:1 to 2:1 gearing), per the same input pedal speed, the output speed is now only half of its previous output speed. Your legs are therefore only moving the bicycle half the distance per the same input pedal speed, so they are only working half as hard to perform the work of moving the bicycle however, they will have to move twice as many times to perform the same work as when pedaling using 1:1 gearing.
The reduced gearing (now 2:1 from the previous 1:1 gearing) has the advantage of doubling the torque applied to the output sprocket at the same time introduces the disadvantage of only half the output speed as the previous 1:1 gearing. Don't confuse the doubling of torque with the doubling of power, as they are entirely different from one another.
Via gearing changes, nothing is gained nor lost power-wise. You are simply better matching the available power per the RPM in which that power is produced to perform the work required to move the bicycle.
  • · Replies 16 ·
  • · Replies 19 ·
10K
  • · Replies 63 ·
  • · Replies 49 ·
9K
  • · Replies 27 ·
22K
