Applying a heat-resistant mark to ceramic
  • Context: Undergrad
  • Thread starter Thread starter m.e.t.a.
The discussion revolves around identifying suitable methods for marking ceramic crucibles that are regularly subjected to high temperatures (up to 550ºC) in a laboratory setting. Participants explore various options for heat-resistant markings, including paints and other materials, while considering the durability and visibility of these markings.
  • One participant suggests using colored chalk, noting its traditional use in foundries for marking hot metal, and mentions that a regular graphite pencil might work depending on the glaze's smoothness.
  • Another participant proposes engine enamel or barbecue paint, stating these are designed to withstand extreme temperatures and could be suitable for the crucibles.
  • A participant recommends Hi-Heat Coating by Cool It, highlighting its resistance to temperatures up to 2000°F and mentioning the availability of temperature indicating paint that changes color at 621ºC.
  • Further details are provided about Tempilaq Temperature Indicating Paints, which come in various temperature ranges and are used for monitoring applications in racing contexts.
  • One participant expresses appreciation for the suggestions and notes the convenience of using ordinary graphite if it proves effective.
  • Another participant inquires about specific brands for temperature indicating paint, indicating interest in practical applications.
Participants present multiple suggestions for marking materials, with no consensus on a single best option. Various viewpoints on the effectiveness of different paints and marking methods remain, indicating an unresolved discussion.
Participants do not fully explore the limitations or specific conditions under which each marking method may fail or succeed, leaving some assumptions unaddressed.
This discussion may be useful for laboratory technicians, materials scientists, or anyone involved in high-temperature applications who seeks effective methods for marking ceramic or similar materials.
m.e.t.a.
http://images.google.com/images?hl=en&q=porcelain crucible&gbv=2
In the lab where I work we have a number of identical-looking ceramic crucibles. It would speed up my job if these could be distinguished from each other by eye. The cruicibles are regularly baked at 550ºC for a period of 3 hours. What type of paint (or other mark) could I apply that will not peel, burn or fade? (Etching or notching/chipping the crucibles is not an option.)
Science news on Phys.org
Coloured chalk is traditional in foundries to mark hot metal,I would have thought a regular graphite pencil would work. Depends on how smooth the glaze is.
Engine enamel, as is used to paint car motors, or barbecue paint would probably work okay. Both are designed to withstand extreme temperatures.
exhaust hedder paint is good to 2000 F
cost $ 10 a can
black or aluminum in color
you also can get temperature indicating paint that changes color up to 621 C
Thank you for replying so quickly. Very helpful suggestions. And if ordinary graphite works then that will be extremely convenient.
Way cool! Do you have a brand name for that?
complete kit is $ 85, has 454C, 510C, 538C, 593C and 649C brush top bottles..each of these cost $18 each...
you can get Brake paint for $ 59 that changes color as temp goes up on calipers..6 distinct colors from 299c to 671C
we get these from pegasusautoracing.com so we can monitor correct fuel jetting and make sure brake pads are in proper range
Thanks. I don't have any immediate need for it, but it's nice to know that it's available.
