Center of mass on inclined plane
The discussion centers on the mechanics of a box with an off-center center of mass (CM) placed on an inclined plane. It concludes that the box will tip over when the CM is positioned above the edge of the base due to gravitational forces acting downward. The critical factor for stability is that the CM must be directly over the base to prevent tipping. The analysis confirms that when the CM is at the top, the box is prone to tipping in the indicated orientation.
  • Understanding of center of mass (CM) and center of gravity (CG)
  • Basic principles of gravitational force
  • Knowledge of inclined plane mechanics
  • Familiarity with stability conditions in physics
  • Study the effects of varying the angle of inclination on stability
  • Explore the concept of torque and its relation to tipping points
  • Learn about the role of friction in preventing tipping on inclined planes
  • Investigate real-world applications of center of mass in engineering design
Physics students, educators, and anyone interested in mechanics and stability analysis of objects on inclined surfaces.
Elbobo
A box with its center of mass off-center as
indicated by the dot is placed on an inclined
plane.
In which orientation does the box tip over?
Teacher didn't even mention anything related to this
Since the CM was at the top, the CG in this case was at the top. Gravity pulls straight downward and nothing is there to support the CM, so it would tip over in option 1, right?
Exactly. In order to not tip over, the center of mass must be over the base.
  • · Replies 36 ·
  • · Replies 68 ·
14K
