Differential Equations: Finding general solution problem
The problem involves finding the general solution of a differential equation expressed in terms of differential operators, specifically (D^4 - I)^2(D^2 - 4D + 13I)^2(y) = 0. The notation includes the identity operator, I, which is causing confusion for the original poster.
  • The original poster attempts to understand the role of the identity operator, I, in the context of the differential equation. They question whether I can be treated as a constant and express concern about the complexity of solving the equation with I present.
Some participants provide clarification regarding the identity operator, suggesting that the original poster may treat I as a constant for the purpose of solving the equation. However, they also emphasize that I is an operator, which introduces nuances in its manipulation.
There is uncertainty regarding the treatment of the identity operator in the equation, and participants are exploring the implications of this notation on the solution process. The original poster's understanding of the notation and its significance is still developing.
kdawghomie
Find the general solution of (D^4 - I)^2(D^2 - 4D + 13I)^2(y) = 0
2. The attempt at a solution
My issue with this problem is that I have no clue as to what the I's mean. I have become familiar with D being used notationally with differential equations, but the introduction of the I's is totally foreign to me, and my professor has never even addressed them. Am I supposed to assume the I's are simply a constant, or am I totally missing something here?
I can break the problem down to the following, though:
[(D^2 + sqrt(I))(D + sqrt(I))(D - sqrt(I))]^2 * [D^2 - 4D +13I]^2 * y = 0
From here, am I supposed to proceed "as usual" with solving the equation... or do the I's have some significance? It seems very possible to solve w/ I's being a constant, but absolutely brutal to actually find the gen. solution for :/
Thank you for any help!
I is usually used for the identity operator: I f = f.
So for example, solving
(D^2 - 3 I) = 0
would mean: find all functions such that
[tex]\frac{d^2}{dx^2} f(x) - 3 f(x) = 0[/tex].
Also used is "id", a 1 with a hat, or a double struck 1.
Physicists tend to leave out the I altogether, and write
(D^2 - 3) = 0
for the above equation.
OK, thank you. So... to clarify, I can essentially ignore the I and just work with the I's coefficient as a constant, correct?
Essentially, yes.
Note however, that I is an operator, just like D is, so you cannot really write sqrt(I) any more than you can sqrt(D). You can use that I^n = I though, for any (integer) n.
  • · Replies 18 ·
