Momentum and Energy gives different answer
The discussion centers on the discrepancy between momentum and kinetic energy calculations in a collision scenario involving two balls with masses of 1g and 100g. The momentum equation, m1v1 = m2v2, yields a final velocity of 0.1 m/s for the second ball, while the kinetic energy equation suggests a final velocity of 1 m/s. The key conclusion is that the collision is inelastic, meaning kinetic energy is not conserved, which explains the differing results from the two calculations.
  • Understanding of momentum conservation principles
  • Familiarity with kinetic energy calculations
  • Knowledge of elastic vs. inelastic collisions
  • Basic physics concepts related to mass and velocity
  • Study the principles of elastic and inelastic collisions in detail
  • Learn about conservation laws in physics, specifically momentum and energy
  • Explore real-world applications of momentum and energy conservation in collisions
  • Investigate the mathematical derivations of momentum and kinetic energy equations
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of momentum and energy conservation in collisions.
halloweenjack
So this may be an easy question, I'm not sure, but I could not find an answer online. Basically here is the scenario.
There are two balls, one has a mass of 1g and the other has a mass of 100g. The 1g ball is traveling at 10m/s, and strikes the other ball. According to momentum, m1v1=m2v2. Using this equation, we have 1g(10m/s)=100g(v2). v2 then equals 0.1 m/s.
The problem I have is that when using kinetic energy, I get a different velocity of the second ball. The first ball has an energy of .5(1g)(10m/s)^2, which is 50 joules. If the first ball then transfers these 50 joules to the second ball, using the same equation I get the second ball having a final velocity of 50=.5(100g)(v^2), or 1 m/s.
Why am I getting different answers? Shouldn't both equations give the same answer?
The answer is simple: The collision as you have established it is not elastic. In other words, energy isn't conserved. In an elastic, head-on collision the small ball will bounce back with nearly the same speed it had before the collision and the big ball will move forward with a tiny velocity:
[tex]m_1 v_{1,\text{init}} = m_1 v_{1,\text{final}} + m_2v_2[/tex]
and
[tex]m_1 v_{1,\text{init}}^2 = m_1 v_{1,\text{final}}^2 + m_2v_2^2[/tex]
Thanks for you help. This helps me in some practice I am getting into be better in mathematics.
  • · Replies 30 ·
  • · Replies 53 ·
  • · Replies 60 ·
  • · Replies 19 ·
  • · Replies 64 ·
9K
