Accelerating charged body, question
The discussion revolves around the forces acting on an accelerating electrically charged large body in free space, exploring concepts such as Lenz's law, inertial mass, and radiation reaction forces. Participants examine the implications of charge on motion and the interaction with electromagnetic fields, touching on both theoretical and conceptual aspects.
  • Some participants inquire about additional forces acting on an accelerating charged body beyond the applied force, questioning the role of Lenz's law.
  • One participant suggests that an electrically charged object may exhibit more inertial mass than a neutral object, making it harder to move.
  • Another participant proposes that momentum may be transferred to waves or photons in the surrounding electromagnetic field, implying a resistive force.
  • A participant mentions the radiation reaction force, suggesting it arises from the electromagnetic field produced by the charge and is not equal and opposite due to the finite propagation time of changes in the field.
  • Concerns are raised about the conceptual difficulty of understanding how reaction forces can enter the field, with references to the Lorentz force and its implications for momentum conservation.
  • One participant introduces the Abraham-Lorentz force, relating it to radiation emitted by a charged particle, while also drawing parallels to effects observed in solenoids without radiation emission.
  • Questions are posed regarding the existence of forces in the case of a large electrically charged mass and how these forces interact with the electromagnetic field.
Participants express differing views on the nature of forces acting on charged bodies, with no consensus reached on the specifics of these interactions or the implications of charge on motion.
Limitations include the dependence on definitions of forces and mass, as well as unresolved mathematical steps related to the radiation reaction and its implications for momentum conservation.
crx
Is there any other force that is acting upon an accelerating electrically charged large body, in free space? Is Lenz's law applying in this situation? I read somewhere that J.J. Thompson observed that is harder to move an object when is charged than when is neutral. If there is a resistive force present as a reaction, what is the support for that force? thanks!
If an electrically charged object has more inertial mass than a neutral object then yes, it's harder to move.
Any other force besides what?
It is that momentum is being transferred to waves/photons of the surrounding EM field.
Mass is the same. I believe that up to a few hundred of gigavolts potential (in case of negative charges) the gained mass can be neglected.
besides the accelerating force...
Then what you're probably looking for is the radiation reaction force. I suppose you might be able to think of it as being exerted by the radiation part of the electromagnetic field that the charge produces (but don't quote me on this).
[added] OK, I take back the second sentence. I should have looked at Griffiths first. It's been a long time since I studied this topic in detail, if I ever did. :rolleyes:
From a quick scan of section 11.2.3 in Griffiths: Divide an extended object (with a continuous charge distribution) into infinitesimal chunks. If the object is accelerating, in general, the force that chunk A exerts on chunk B is not equal and opposite to the force that chunk B exerts on chunk A. The important factor here is apparently the fact that it takes a finite amount of time for changes to propagate from A to B and vice versa; Griffiths uses the "retarded fields" in his derivation. When you add up the resulting unbalanced forces on all possible pairs of chunks, you get a net force on the object, which is the radiation reaction force. Apparently this force doesn't go to zero when you take the limit as the size of the object approaches zero. The result is the Abraham-Lorentz formula for radiation reaction, which can also be derived by using conservation of energy.
I'm definitely not an expert in this, so don't push me much further on this (and others are welcome to correct me), but at least now you have some keywords and names to search for.
I find it conceptually difficult to think of the reaction force going into the field. There is another mysterious case in E&M where there is apparently no reaction. The Lorentz force for the force acting on a charged particle in a B field.
F = q VXB
In fact, the posed question is a specific case of this problem. There is a book recently published by one of my professors where he addresses this problem. He is able to satisfy Newton's second law, and thus conserve momentum without putting momentum into the field. If I remeber correctly, I believe the special relativistic corrections come out of his formulation of the field equations.
A Promenade Along Electrodynamics (Paperback)
by Junichiro Fukai
Unfortunately, there are many errors in this first edition
flatmaster said:
I find it conceptually difficult to think of the reaction force going into the field. There is another mysterious case in E&M where there is apparently no reaction. The Lorentz force for the force acting on a charged particle in a B field. [..] In fact, the posed question is a specific case of this problem.
Sure, the Lorentz magnetism force can be reduced to an electric force in the particle's rest frame by noticing relativistic effects to the source of the external field. But here is different in that there is no external field source, so there is nowhere but the field itself for the missing momentum to go.
I just find out that there is a force called Abraham-Lorentz force caused by the "recoil" of the radiation emitted by a charged particle that "jerks" (check wikipedia) at non relativistic speed.
But...there is a similar phenomena in a solenoid when the self induced magnetic field will oppose to the quick variations of the electric current in the coil. There is no radiation emitted, or can be neglected. This effect is used to smooth ripples in dc current (smoothing reactor). It seems like the magnetic field its freezing in space and will interact with the moving charge that created it. But there is no magnetic field before the charge is getting there?(OK this one is just a relativistic view...). So what is going on? Can this effect appear in the case of a large electrically charged mass?
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 36 ·
