How High Does a Ball Go If Thrown Upwards at 40m/s?
  • Thread starter Thread starter cyberhev
The problem involves determining the maximum height reached by a ball thrown vertically upwards with an initial velocity of 40 m/s, while considering gravitational effects.
  • Participants discuss the appropriate equations for motion under gravity, with one participant suggesting the use of V^2 = u^2 + 2as. Questions arise regarding the correct interpretation of initial velocity and the role of gravity in the calculations.
Some participants have provided guidance on using the correct equation and have pointed out the need to consider the effects of gravity on the ball's velocity. There is an ongoing exploration of the relationship between time, velocity, and height, with multiple interpretations of the variables involved.
Participants are working under the assumption that air resistance can be ignored and that gravitational acceleration is 9.8 m/s². There is also a noted typo regarding the units of acceleration.
cyberhev
Height reached by a ball if it is thrown vertically upwards with an initial velocity of 40m/s
Using V^2=u^2+2as
I have been told to ignore air resistance and let g =9.8 m/s. Any help anyone?
Well you have the correct equation. Just plug in all the variables and solve for the displacement s.
Consider that the balls's velocity of 40 m/s is being sapped away by gravity at a rate of 9.8 m/s/s. How much time (t) will it take for v to be reduced to zero?
What will the ball's average velocity be over time period t? (Now you can solve for h.)
(Also: you probably just made a typo but note that g is an acceleration and as such takes the unit "m/s/s", normally written "m/s2". "m/s" is a unit of velocity, not acceleration.).
Thank you! Yes it was a typo! I am right that even if this question states initial velocity is 40m/s the actual value of u in this question is zero? Also my transposition of this equation works out to be V^2-u^2 divided by 2a=s?
Yes the final velocity is 0 for that equation.
So for your equation:
0 = 402 +2*(-g)*x
(if +X is up, then g carries a - sign.)
If time is all you want then you have an easier path with
|V| = |g|*t
t = V/g
  • · Replies 38 ·
  • · Replies 31 ·
