Why Use VA Instead of Watts for Electrical Measurements?
  • Thread starter Thread starter es1
The discussion revolves around the use of volt-amperes (VA) versus watts (W) in electrical measurements, particularly in the context of AC power and reactive loads. Participants explore the definitions, implications, and conventions surrounding these units, addressing both theoretical and practical aspects.
  • Some participants note that while a watt is defined as a volt multiplied by an ampere, this definition applies primarily to resistive loads.
  • Others argue that for reactive loads, the phase difference between current and voltage complicates the relationship, leading to variations in power measurements.
  • It is mentioned that VA is used in cases where the load can be reactive, and this usage is more of a convention than a strict rule.
  • One participant clarifies that VA represents the product of RMS voltage and RMS current, which is not the same as average power, and that VA can exceed the real power consumed.
  • Another participant highlights that residential customers typically do not pay for reactive power, but are billed based on real power consumption.
  • A question is raised regarding the apparent power rating of a UPS, prompting discussion about the phase characteristics of battery power and sine waves.
Participants express a range of views on the definitions and implications of VA versus W, with no consensus reached on the nuances of these concepts. Some points are clarified, but disagreements about the interpretation of power measurements remain.
Participants reference the RMS values and the relationship between voltage and current in AC systems, but there are unresolved aspects regarding the implications of phase differences and the definitions of power types.
This discussion may be of interest to electrical engineers, students studying electrical engineering concepts, and professionals dealing with power measurements in AC systems.
es1
I thought a watt by definition was a volt * ampere.
However many safety documents use the unit VA and not W where presumably VA also equals volt * amp.
I am just curious, why the new unit?
That definition of a watt only works for a resistive load. When the load is reactive, the current and voltage are not in phase (in general), and multiplying their instantaneous values won't give you the real power picture.
It's used by electrical engineers because for some AC power applications with a phase difference between the current and voltage the power varies.
For the simplest case of purely resistive loads, rms power = rms V * rms A
Oh I get it. The symbols change because the units change. W is an instantaneous unit and VA is average power over a cycle? So why VA and not J? :)
No, the units are the same.
The difference is that VA is used for cases where the load is or can be reactive, it is more a convention than anything else.
Joule is the unit for the time integral of power; I.e. 1 J =1 Ws or 1 VAs (s is second).
http://en.wikipedia.org/wiki/Volt-ampere
VA is not the average power, but the product of the RMS voltage and RMS current (each a sort of average--see the Wikipedia or Mathworld articles on RMS for more details), and will be higher than the 'real' power used. Also, you typically pay for your Volt-Amperes, and not your Watts (because the generator has to work harder, and you need additional capacity).
Not quite es1. The difference in watts and VA is that at every point along the sine wave of a voltage driving a resistive load ohms law holds true and of course averaged it would too. But, when driving a reactive load the current is out of phase with the voltage by up to 90 degrees. So yes the average current and the average voltage do in fact agree with ohms law. But since the current and voltage are out of phase it is impossible for ohms law to hold true during every instant of the sine wave. This is why it is called VA. Real power is not being dissipated as it would in the watt. So your average power over a cycle statement is correct and to be honest I'd never thought of it that way until now, EXCEPT the part about power. It isn't really power since the current and voltage are not in phase.
Residential customers do NOT pay for reactive power.
Which brings us to the VAR; http://en.wikipedia.org/wiki/Volt-amperes_reactive"
Thanks Guys. I think this clears it up for me. Post #7 makes a lot of sense too. Thanks Averagesupernova.
I also found this link.
And learned a new term. "Apparent Power" whose unit is the VA.
What a day! :)
Another question - why does the UPS I just bought claim to be 650VA (300W) on the box?
Is there something very odd about the phase characteristics of battery + sine wave I'm not aware of?
That's true (I'm billed per kWh). Having just checked, in my neck of the woods, you only get dinged if you have low power factor, and most residences don't have low enough power factor to get dinged. No clue what that number is, however.
Yes es1, apparent power. Somehow reactive power didn't look right when I typed it out. Apparent would be the correct wording.
12K
