Compressed gas and heat transfer
The discussion centers on the thermodynamic principles of compressed gas and heat transfer, specifically regarding a 100ml cylinder of air compressed to half its volume. Compression increases the gas temperature and pressure, but if the system is non-adiabatic, heat loss occurs to the surroundings, preventing a return to atmospheric pressure. Upon release, the gas will re-absorb some heat energy, resulting in a temperature increase, but irreversibilities prevent complete recovery of the original state.
  • Understanding of thermodynamics, specifically the ideal gas law
  • Knowledge of heat transfer mechanisms in non-adiabatic systems
  • Familiarity with concepts of pressure and temperature relationships in gases
  • Basic principles of energy conservation and irreversibility in thermodynamic processes
  • Explore the ideal gas law and its applications in real-world scenarios
  • Study non-adiabatic processes and their effects on gas behavior
  • Investigate heat transfer methods and their impact on system efficiency
  • Learn about thermodynamic irreversibilities and their implications in engineering
Engineers, physicists, and students in thermodynamics or mechanical engineering who are interested in the behavior of gases under compression and heat transfer principles.
ProtoBob
compressed gas...and heat transfer...
If you were to take a cylinder of air, at room temp, and let's say it is 100ml in volume.
If you were to take this cylinder of air, compress its volume to half its size, how much heat
would that create (btu's) and if the heat were to dissipate, would the air inside the cylinder then be back at atmospheric pressure?
If not back at atmospheric pressure, and (assuming there is still some pressure) the air were
then released, would it reabsorb the energy that was dissipated after it was compressed? i.e. would it then cool the surrounding room back to the original temperature?
Thanks!
Science news on Phys.org
Thanks!
Heat is not created (heat is a transfer mechanism for energy across a boundary), although there would be an increase in the temperature of the gas due to the compression along with the pressure increase. If the cylinder is non-adiabatic then energy would be lost due to heat transfer to the surroundings. This would result in a slight pressure loss but not back to atmospheric pressure.
Irreversibilities are never recoverd from a system once incurred. The air would be heated once released from the cylinder so it would "re-absorb" some of the heat energy.
CS
  • · Replies 20 ·
  • · Replies 28 ·
  • · Replies 109 ·
10K
