Register to reply
Volume Flow Rate
by kathmill
Tags: flow, rate, volume
Share this thread:
kathmill
#1
Dec16-08, 06:16 PM
P: 4
A pump at ground level creates a gauge pressure of 102 kPa in the water line supplying an apartment building. The water leaves the tank into a pipe at a negligible speed. It travels up 10 m through the building and exits through a faucet. The cross-sectional area of the faucet is 2.0 cm^2. What is the Volume Flow Rate of the water leaving the faucet in cm^3/s?
2. Relevant equations
Volume Flow Rate: Q=Av
Bernoulli equation simplified: v = square root of: (Gauge Pressure - density of water*g*height)/(1/2 density)
So put V into Q=Av and solve!?
3. The attempt at a solution
I found it to be: 8 cm^3/m
Where am I going wrong?
Phys.Org News Partner Science news on Phys.org
Study links polar vortex chills to melting sea ice
Lab unveil new nano-sized synthetic scaffolding technique
Cool calculations for cold atoms: New theory of universal three-body encounters
Doc Al
#2
Dec17-08, 07:38 AM
Mentor
Doc Al's Avatar
P: 41,489
You solved for the speed v (in m/s). You need the volume flow rate, which is Av.
Register to reply
Related Discussions
Ppm and flow rate General Physics 4
Volume Flow Rate, Help? Introductory Physics Homework 1
Measuring volume flow rate Mechanical Engineering 9
Simple volume flow rate calculation Introductory Physics Homework 2
Flow rate Introductory Physics Homework 2
