Problem With fundamental theorum of Calculus
The discussion revolves around the application of the Fundamental Theorem of Calculus in the context of differentiating an integral with variable limits. The original poster presents a problem involving the function F(x) defined as an integral from 0 to cos(x) of e^(t^2) and seeks to find F'(\pi/2).
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the differentiation of F(x) and the application of the chain rule due to the upper limit being a function of x. There are attempts to clarify the difference between standard applications of the Fundamental Theorem of Calculus and the specific case presented.
The discussion is ongoing, with some participants providing guidance on the necessity of applying the chain rule. There is recognition of confusion regarding the differentiation process, and attempts to clarify the correct approach are being made.
Some participants express uncertainty about the application of the chain rule and the implications of the upper limit being a function rather than a constant. The original poster's reference to the book's answer indicates a potential misunderstanding of the differentiation process involved.
Titans86
The question: F'([tex]\pi[/tex]/2) if F(X)= [tex]\int^{cosx}_{0} e^{t^{2}}[/tex]
I thought I thought F'(X) = f(t) = e^{t^{2}} replacing t with cos^{2}x
But my book writes:
F'(x) = [tex](-sinx)e^{cos^{2}x}[/tex]
the deal is that you need to apply chain rule here, since your upper limit bound of integration is not an independent variable, but rather a function as well.
I assume your question is, "Find the value of [itex]F'(\pi/2)[/itex], given
[tex]F(x)=\int_0^{\cos x}e^{t^2}\,dt\;.[/tex]
The fundamental theorem of calculus states that if
[tex]F(x)=\int_a^x f(t)dt\;,[/tex]
then
[tex]F'(x)=f(x).[/tex]
Can you see how this differs from your problem?
hmm... I'm sorry but I still don't see it...
The book then substitutes pi/2 into the F'(x) that I wrote above and ends it there...
the final answer is -1...
What does the chain rule say?
if you have[tex][F(g(x))]'=F'(g(x))*g'(x)=e^{cos^2x}(cosx)'=?[/tex]
In your problem you have g(x)=cosx and
[tex]F(g(x))=\int_0^{\ g(x)}e^{t^2}\,dt=\int_0^{\cos x}e^{t^2}\,dt[/tex]
Now just look above and you are done.
Ah, I see what's going on...
I was differentiating [tex]e^{cos^{2}x}[/tex] which was giving me something else...
