How Far Will Jenny Slide on Flat Ground After Sledding Downhill?
  • Thread starter Thread starter PvtDonutDJ88
    Friction
The problem involves a scenario where Jenny, with a total mass of 40 kg, sleds down a hill and reaches a speed of 6 m/s at the bottom. After reaching the flat ground, she slides to a stop, and the coefficient of friction between the sled and the ground is given as 0.04. The objective is to determine how far she will slide on the flat ground.
  • Participants discuss the relationship between kinetic energy and the work done by friction to find the distance Jenny slides. There are attempts to calculate the normal force and frictional force, as well as questions about how to derive acceleration from the given information.
The discussion is active, with participants exploring different approaches to relate kinetic energy and frictional force. Some guidance has been provided regarding the calculations needed to find the distance, but there is no explicit consensus on the method to be used.
Participants are navigating through the constraints of the problem, including the need to connect kinetic energy with the work done by friction and the variables involved in the calculations.
PvtDonutDJ88
While sledding down a hill Jenny(40kg with the sled) reaches a top speed of 6m/s at the bottom. She then slides on flat ground to a stop. If the coefficient of friction between the sled and the ground is 0.04 how far will Jenny slide?
VF2=VI2+2a[tex]\Delta[/tex]X
([tex]\Delta[/tex]X=total distance)
VF=VI+at
FN=mg
FF=FNU
I have found FN and got 392(FN=mg, or FN=(-40kg)(-9.8)=392) then found the total frictional force that was 15.68(FF=FNU, or FF=(392)(.04)=15.68) I'm having problems finding the acceleration, so i can actually find the distance, how can i take the info i have now and plug it into an equation to find acceleration? If i need a different equation than i have there, please show me, I'm confused on what to do next
This is a Kinetic Energy to work problem.
The KE of Jenny will be equal to the Force of friction * the distance to stop - i.e the work that friction will do to gobble up her kinetic energy and stop her.
So KE=(FF)([tex]\Delta[/tex]X) am i looking for kinetic energy? to get my distance? or what? I'm still a little confused because i only have FF=15.68 i still have two variables? or does KE equal something?
You know the initial speed and mass so you can calculate the initial kinetic energy.
The friction force is her weight (NOT mass) times the coefficient of friction. The work done by friction is the product of that force and the unknown distance. Set equal to the initial kinetic energy and solve for the distance.
oh ok i get it thank you!
18K
