What is the angle of the plane with respect to the horizontal?
The problem involves a block of mass 19.0 kg sliding down an inclined plane at constant speed, with a coefficient of kinetic friction of 0.24. The objective is to determine the angle of the plane with respect to the horizontal, given the conditions of motion and forces acting on the block.
  • Participants discuss the implications of the block moving at constant speed, questioning how this affects the net forces acting on the block. There is confusion regarding the relationship between the normal force, friction force, and gravitational force.
Some participants have offered guidance on balancing the forces acting on the block, suggesting the use of free body diagrams (FBD) and the resolution of forces into components. Multiple interpretations of the forces involved are being explored, with some participants questioning the equations provided and the assumptions made about the forces.
There are indications of missing information regarding the setup of the problem, particularly in the definitions of the forces and their relationships. Participants are grappling with the correct application of equations related to the forces acting on the block.
reaperkid
A block of mass 19.0 kg is sliding down an inclined plane. Due to friction between the block and the plane the block is moving at constant speed. If the coefficient of kinetic friction is 0.24), what is the angle of the plane with respect to the horizontal ?
m = 19kg
mu = .24
theta = ?
Fk = mu*Fn
Fn = g sin theta
I'm confused about the hint of the block moving with a constant speed due to friction.. Because that means that the net force is 0, so how can I calculate this if one of the forces is equal to 0?? I can't get the normal force without the angle and I can't get the friction force without the normal force.. Can anybody help me out with what that clue implies?
Thanks!
Hi reaperkid! :smile:
(have a mu: µ and a theta: θ :wink:)
There are three forces … normal, friction, and gravitational …
so just balance them to add to zero
(either by using components, or a vector triangle ) :smile:
Soo does that mean the normal force is equal to the gravitational force?
no, draw a FBD
Bright Wang said:
no, draw a FBD
Ughhh, I don't know how to get the normal force or friction force. If I could get either of those then it would be easy to balance them. And isn't friction the only negative force here?
Nevermind I got it, thanks!
I think you should sketched the vector forces. I will give you a hint. There will be two components that make up the forces: The x-component and the y-component. Identify the forces in the x-directions and identify the forces in the y direction. What do you think the value of the acceleration in the y-direction will be?
Assume that angle with horizontal is theta.
mu = 0.24
You have written Fn = g sin theta
I think you missed m. Moreover, it should be cos, not sin.
Draw the diagram. You will find that correct is
Fn = mg cos(theta)--------------------(1)
You have written Fk = mu * Fn
i.e. Fk = 0.24 Fn-----------------------(2)
You got two equations (1) and (2). By resolving forces parallel to the incline and making net force in this direction as zero, you will get one more equation:-
Fk = mg sin(theta)-----------------(3)
You should be able to find theta from these three equations.
  • · Replies 27 ·
