The sign of Gravitational Potential Energy
The discussion revolves around the concept of gravitational potential energy (GPE) and its mathematical representation. Participants are examining the definition of GPE in relation to the work done when bringing two particles from infinite separation to a distance "R" apart, particularly focusing on the sign of the potential energy value.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the definition of gravitational potential energy and the implications of work done by forces. Some question the interpretation of the forces involved, particularly whether the force referenced is gravitational or another applied force. Others discuss the integration process and the limits used in calculating the potential energy.
The discussion is ongoing, with participants providing insights and clarifications regarding the sign of the gravitational potential energy. There is an exploration of different interpretations of the work done and its relation to potential energy, but no explicit consensus has been reached.
Participants are working under the assumption that gravitational potential energy is defined with respect to infinite separation, and there are discussions about the implications of this definition on the calculations being performed.
ritwik06
I read this statement:
"The gravitational potential energy of a particle at a point with respect to another particle (kept at rest) is equal to the work done by the force which brings them from infinite separation at that point, without gain in kinetic energy."
Then I tried to mathematically calculate th value of gravitational potential energy when the particles are at a distance "R". Here is what I did.
As there is no gain or loss in kinetic energy, I take my force exactly equal to the gravitational attraction between th particles, but opposite in direction.
The work done when th body is displaced by a distance dr=
[tex]\frac{-Gm_{1}m_{2}.dr}{r^{2}}[/tex]
This must be negative as th force and the displacement are in opposite directions.
Integrating it with limits :
[tex]^{r}_{\infty}\int\frac{-Gm_{1}m_{2}.dr}{r^{2}}[/tex]
=Gm1m2/r
But the answer given in my book is negative, with the same magnitude. Where have I committed a mistake?
Hi ritwik06,
I think you may be misreading this statement. The "force" that this statement is referring to is another applied force, not gravity. For example, if I am required to do 50 J of work to push a particle from infinite separation to a point R (with no kinetic energy gain), then the particle has a PE of 50 J at that point. So this statement is the conservation of mechanical energy equation for the case of no change in kinetic energy and no initial potential energy, and with work done by a non-conservative force:
[tex] W_{\rm NC} = PE_f [/tex]
(which follows from Wnc=(change in kinetic energy)+(change in potential energy)).
In your case, what I think what you want to calculate with is the definition of potential energy, which is that the potential energy difference (associated with some conservative force) is equal to the negative of the work done by that conservative force:
[tex] \Delta {\rm PE} = -\ W_{\rm C}[/tex]
You'll set PEi=0 since it is at infinity for your integral, and then that should clear up the sign difference.
=Gm1m2/r
Here's how I would look at it:
Good. Note that the force acts in the direction of positive r, thus it is:
[tex]\frac{Gm_{1}m_{2}}{r^{2}}[/tex]
Note that dr is intrinsically in the direction of positive r, so an element of work is:
[tex]dW = \frac{Gm_{1}m_{2}}{r^{2}}dr[/tex]
The work done, and thus the gravitational PE at r = R, will be negative when your limits of integration go from ∞ to R.
Ok! Positive r is in the direction from the fixed mass to the moving mass, right? Force is +ve.
Will the element of work done for a small displacement +ve? the force is positive but the displacement is in opposite direction, isn't it?
and,
Merry Christmas!
It depends on which direction you go in. If your displacement is in the direction of positive r (you are separating the masses) then the work is positive and the change in PE is positive.
We define gravitational PE with respect to infinite separation, so in that case the displacement is opposite to the force (we are bringing the masses together) and the work done (and change in PE) is negative.
[tex]\text{GPE} \equiv \int_{\infty}^R dW = \int_{\infty}^R\frac{Gm_{1}m_{2}}{r^{2}}dr = -\frac{Gm_{1}m_{2}}{R}[/tex]
and,
Merry Christmas!
It's Newton's birthday!
At the time Newton was born, England was still using the Julian calendar and had not yet switched to the Gregorian Calendar. The day of Newton's birth was indeed Dec 25 on the Julian Calendar (though Christmas was not considered a major holiday then) but is normally now given as Jan. 4 on the Gregorian Calendar.
Exactly! See: https://www.physicsforums.com/showthread.php?t=281462"
  • · Replies 43 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 22 ·
