Understanding Vector Spaces: Definition and Examples | Vector Calc Answer Check
  • Thread starter Thread starter franky2727
    Vector
This discussion focuses on the definition and properties of vector subspaces, specifically in the context of vector spaces over a field K. The criteria for a subset W to be a subspace of a vector space V include containing the zero vector, closure under vector addition, and closure under scalar multiplication. The participants analyze specific examples of subspaces in R3, such as W1 defined by the equation x1 + 5x2 + 6x3 = 0, which is confirmed to be a subspace, and W2 defined by the product x1*x2*x3 = 0, which is proven not to be a subspace. Additionally, they explore direct sums of subspaces, concluding that certain combinations do not form direct sums due to non-trivial intersections.
  • Understanding of vector spaces and subspaces
  • Familiarity with linear combinations and closure properties
  • Knowledge of scalar multiplication in vector spaces
  • Basic concepts of direct sums in linear algebra
  • Study the properties of vector spaces over different fields, such as R and C
  • Learn about linear independence and basis in vector spaces
  • Explore the concept of dimension in vector spaces
  • Investigate the criteria for direct sums and their applications in linear algebra
Students of linear algebra, mathematicians, and educators looking to deepen their understanding of vector spaces and subspaces, particularly in the context of R3 and their properties.
franky2727
Hi all, I'm currently revising for a second year moduel by looking through past exam
papers, i don't have the answers to these papers but i do have similar questions so i'm
trying to piece together the answers from what i do have, i think this is right but would
be greatful if someone could check it through so I'm not revising the wrong thing for the
next few weeks, thanks
1(a) Let V be a vector space over field K. What is meant by saying that W is a vector
subspace of V?
my answer: Assuming W as a subset of V, W is a subspace if and only if the following 3
criteria are satisfied
(I)W contains the zero vector
(II)if uand vare elements of W then so is (u+v)
(III) If u is an element of W and c is a scalar from K then cu is also an
element of W
(b) Which of the following are vector supspaces of R3? Give proofs or
counterexamples. as appropriate.
(i) W1 ={(x1,x2,x3E R3) :
x1 + 5x2 + 6x3=0
(I)If (x1,x2,x3) E W1 and (x4,x5,x6) E W1
so that x1 + 5x2 + 6x3=0
and x4 + 5x5 + 6x6=0
then (x1+x4,x2+x5,x3+x6)
lies in this space since we get
(x1+x4) +5(x2+x5) +6(x3+x6)= (x1+5x2+6x3)+(x4+5x5+6x6)=0
(III) If (x1,x2,x3) E W1 and c E R ( is this R or R3)?
then x1+5x2+6x3=0 implies that cx1+5cx2+6cx3=0c
therefore c(x1+5x2+6x3)=0
therefore C0=0 therefore W1 is a subspace of R3 as this holds also
(ii)W2 ={(x1,x2,x3E R3) :
x1*x2*x3=0
x1,x2,x3=(0,0,0) satisfies x1*x2*x3=0
(II)if (x1,x2,x3 E W2) and
(x4,x5,x6 E W2
so that x1*x2*x3=0 and x4*x5*x6=0
then (x1+x4)*(x2+x5)*(x3+x6)=(x1*x2*x3)+(x4*x5*x6)=0
this is not the case as (1,0,0) and (0,2,2) would both satisfy x1*x2*x3=0 but together would give (x1+x4)*(x2+x5)*(x3+x6)+4 therefore W2is not a subspace of r3
thanks in advance for checking it through hopefully its right
Few more questions I've attempted now, pritty sure these are right but a 2 minute check over can't hurt right? thanks again
consider the following subspaces of R3
U={(a+3b,a,b) : a,b E R V={(c,0,0) : c E R W={(4d,d,d) : d E R
giving brief reasons, determine whether or not
(i)R3 =Udirect sumV
(ii)R3=Udirect sumW
(iii)R3=Vdirect sumW
only done the first one so far but will update/edit as i complete the others
(i) check that VnW=(0,0,0), if (x,y,z)=(a+3b,a,b)=(c,0,0)
then we have x=a+3b,y=a=0,z=b=0
this gives a=0,b=0 and therefore c=0
i.e. (x,y,z)+(0,0,0)
next we show every vector (x,y,z) can be written w+v with vE V and w E W
we need to solve x=a+3b+c
y=a
z=b
and we can getting
b=z
a=y
c=x-y-3z
i believe that the mere fact that these solve shows that they are a equal to R^3? correct me if I'm wrong thanks :)
(ii) bit stuck on this one or might just not be sure what my answer shows
first check that UnW=(0,0,0) i don't think it does because i get
(x,y,z)=(a=3b,a,b)=(4d,d,d)
then x=a+3b=4d,y=a=d,z=b=d
which i can't make a zero out of so i can't get (x,y,z)=(0,0,0) so i believe this shows me not only that R^3doesnt equal Udirect sum W but it also shows that there not a direct sum in the first place?
just took another look at it now and I'm almost convinced I'm right with (4,1,1) being an example of a non zero vector?
(iii)
without writing it all out at the end i get d=z=y and c=x-4d so i get c=x-4y or c=x-4y, does this show that it does work as the equations are solvable or does the d=z=y alter things some how?
subspace of V?
element of W
Looks ok. You could also combine II and II by noting that [tex]au+bv \in W[/tex] if given a,b are any elements of K and u,v are any vectors in V.
x1 + 5x2 + 6x3=0
It's R.
You should also show that the zero vector is also present in this subspace, for which x1=x2=x3 = 0.
x1*x2*x3=0
(x4,x5,x6 E W2
Yes, that is a correct counter-example.
(i)R3 =Udirect sumV
(ii)R3=Udirect sumW
You meant UnV, right.
Yes, ok to me.
y=a
z=b
and we can getting
b=z
a=y
c=x-y-3z
Yes, looks ok. You've shown how to find values of a,b,c (and hence vectors belonging to U and V) such that any (x,y,z) in R3 is expressible in terms of these. And as above, you meant U,V not W I guess.
If you wrote the three subspaces U,V,W as the linear span of some vectors you should be able to see that the sole vector in the basis of W is a linear combination of the other two vectors in the basis of U. Then clearly it can't be a direct sum since [tex]U \cap W \neq {\mathbf{0}}[/tex].
(iii)
Again it helps you have already expressed the three subspaces in terms of linear spans of some specified basis. Then take note of the number of linearly indepedent vectors in [tex]V\oplus W[/tex].
thanks mate, most helpful
