Thread Closed
Find the final volume
Share Thread Thread Tools
Dec21-08, 03:42 PM   #1
KFC
Two ideal gas (n mole A and m mole B) was separated by a piston (impermeable and diathermal) the whole setup is confine in a adiabatic walls so no heat exchange with outside. Let the piston move, at equilibrium, find the final volume. Assume the final temperature of both gas is T and the total volume is V.
2. The attempt at a solution
First of all, both gas satisfy ideal gas state equation
[tex]
\frac{P_AV_A}{T_A} = nR, \qquad \qquad \frac{P_BV_B}{T_B} = mR
[/tex]
Since we know the final temperature, and at equilibrium, the pressure is the same on both compartment (otherwise, the piston will move), so assuming the final volume of A is [tex]V_A[/tex], then the final volume of B will be [tex]V-V_B[/tex], we conclude that
[tex]
\frac{P}{T} = nRV_A = \frac{P}{T} = mR(V-V_A)
[/tex]
We can solve for [tex]V_A[/tex] and [tex]V_B[/tex], right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec22-08, 03:29 AM   #2
Recognitions:
Homework Helper Homework Help
Your setup looks correct, except for a mathematical error...
If [itex]\frac{P V}{T} = n R[/itex], then [itex]\frac{P}{T} = \cdots [/itex] ?
By the way, once you have found the answer, it'll be nice trying to explain its physical meaning and saying something about whether you could have foreseen the outcome.
Dec22-08, 12:16 PM   #3
KFC
Quote by CompuChip View Post
Oh, careless. Thanks
Thread Closed
Thread Tools
Similar Threads for: Find the final volume
Thread Forum Replies
Find the final velocity of the railroad car. Introductory Physics Homework 2
Find the final momentum Introductory Physics Homework 1
mometum and how to find an initial and final momentum Introductory Physics Homework 5
Finding Final Volume - almost got it Introductory Physics Homework 2
Very Difficult : Finding final Volume gasses (for me) Chemistry 10
