What is the significance of μ in oblate spheroidal coordinates?
  • Context: Graduate
  • Thread starter Thread starter tony873004
    Coordinates Earth
The discussion centers on the significance of the parameter μ in oblate spheroidal coordinates, particularly in relation to plotting oblate spheroids and understanding their geometric properties. Participants explore the definitions and implications of μ and its relationship with the scale parameter a, as well as the application of these coordinates in modeling the Earth's gravity.
  • One participant questions the definition of μ, suggesting it describes the oblateness of an object and speculating on its range, initially guessing it to be between 0 and 1.
  • Another participant clarifies that μ is a coordinate and a is a scale parameter, indicating that surfaces of constant μ are oblate spheroids and that a sphere can only be approached with large μ values.
  • A participant experiments with code to plot oblate spheroids, noting that varying μ leads to different shapes, and finds that larger μ values yield more spherical shapes.
  • There is a suggestion to use stretched spherical coordinates for plotting, which may simplify the representation of oblate spheroids.
  • Participants discuss the challenges of using either coordinate system for computing the strength of Earth's gravity, with one suggesting the use of spherical harmonics for more accurate modeling.
  • Another participant inquires about the significance of the C2,0 coefficient in relation to Earth's oblateness and whether it should be used as is or negated in calculations.
  • There is a discussion about the validity of modifying the gravitational potential formula to reflect acceleration rather than potential, with a participant noting that the behavior aligns with expectations as the distance increases.
Participants express differing views on the interpretation of μ and its role in defining the shape of oblate spheroids. There is no consensus on the exact nature of μ or its implications for plotting, and the discussion remains unresolved regarding the best approach for modeling Earth's gravity.
Participants highlight limitations in understanding the relationship between μ and a, as well as the implications of using different coordinate systems for gravitational calculations. There are unresolved mathematical steps regarding the application of spherical harmonics and the treatment of coefficients in gravitational potential equations.
tony873004
oblate spheriod
From http://en.wikipedia.org/wiki/Oblate_spheroidal_coordinates I'm given the formulas to compute cartesian coordinates from oblate spheroidal coordinates.
[tex] \begin{array}{l}<br /> x = a\cosh \mu \,\,\cos \nu \,\,\cos \phi \\ <br /> y = a\cosh \mu \,\,\cos \nu \,\,\sin \phi \\ <br /> z = a\cosh \mu \,\,\sin \nu \\ <br /> \end{array}<br /> [/tex]
But I've got a few questions:
I've written a short block of code to plot an oblate spheroid:
Code:
mu = 0.5
For a = 0 To 100
    For nu = 0 To (2*pi) Step 0.02
        For phi = 0 To (2*pi) Step 0.02
            x = a * cosh(mu) * Cos(nu) * Cos(phi)
            y = a * cosh(mu) * Cos(nu) * Sin(phi)
            z = a * sinh(mu) * Sin(nu)
            Call PlotPoint(x, z)
        Next phi
    Next nu
Next a
What is μ ? I don't see it defined on Wikipedia's page. I image it is a number that describes how oblate the object is. So I imagine there should be a number I can set it to that gives me a sphere. My guess would be that mu can range from 0 to 1, with one of those limits giving me a sphere.
So I tried it. I see that μ = 0 gives me a straight line, meaning completely oblate, and the larger I set this number, the more spherical the shape becomes. But it seems to become a sphere at μ = 2, contrary to my guess. Any value larger than 2 gives me a larger sphere. Does anyone know exactly what μ is, and what it's range is?
Also, I see Earth described as an oblate spheroid. What is its μ value?
Thanks!
I think you have μ and a backwards: μ is one of the coordinates, and a is a scale parameter. The surfaces of constant μ are oblate spheroids; they are never spheres, since cosh μ and sinh μ never coincide. For large μ they may appear to be very close, though, so it would look quite like a sphere. If you're plotting using this coordinate system, you want to keep a constant and vary μ. The reason the coordinate system is defined that way is to make it orthogonal. You will only get a sphere if μ is very large (and a is accordingly small).
If you're just trying to plot an oblate spheroid, you might consider using stretched spherical coordinates like such:
x = r sin θ cos φ
y = r sin θ sin φ
z = kr cos θ.​
where your coordinates are (r, θ, φ) and k is a parameter.
Thanks.
The Wikipedia article says "Thus, the two foci are transformed into a ring of radius a in the x-y plane." That's why I was assuming that a defined the size and μ defined the shape.
I just tried swapping 'a' and μ in my code. Now as it draws concentric shells, they start out oblate and become more spherical the larger μ becomes. Before, the oblateness was consistent between the concentric shells, and their size varied from 0 to max as 'a' got larger.
x = r sin θ cos φ
y = r sin θ sin φ
z = kr cos θ.
Ulitmatey, what I'd like to do is a triple integral so I can compute the strength of Earth's gravity at a defined point in space, without approximating Earth as a point mass.
In that case, either coordinate system would work in principle, but it's probably a mess either way. I'm thinking it's probably better to use the stretched spherical coordinates, since in that case the volume element is just dV = kr2 sin θ dr dθ dφ.
Use spherical harmonics instead. You can get spherical harmonics coefficients to more accuracy than you get ever envision using off the web. The gold standards
For a brief description of spherical harmonics as used in the realm of gravity modeling, see http://www.cdeagle.com/pdf/gravity.pdf. Also see Vallado, "Fundamentals of Astrodynamics and Applications".
For low accuracy (but better than a point mass model), you can just use the second-order zonal harmonic, J2 component, the negative of the unnormalized C2,0 component: J2 = 0.00108263.
The Earth's potential with this second-order zonal harmonic term is
[tex]U(r) = \frac {GM_{\text{earth}}} {r} \left(1+\left(\frac a r)^2 P_{2,0}(sin\phi)C_{2,0}\cos 2 \lambda+\cdots\right)[/tex]
where
  • [itex]P_{2,0}(x) = \frac 1 2 (3x^2 - 1)[/tex] is the second associated Legendre polynomial<br /> [*][itex]a=6,378.135\,\text{km}[/itex] is the Earth's equatorial radius<br /> [*][itex]r[/itex] is the radial distance from the center of the Earth to the point in question<br /> [*][itex]\lambda[/itex] is the longitude of the point in question<br /> [*][itex]\phi[/itex] is the <i>geocentric</i> (not geodetic) latitude (i.e. simple spherical geometry)[/itex]
[itex][/itex]
Thanks Adriank and DH. How does this formula know how oblate Earth is? Is it in C 2,0? For C 2,0, do I use .00108263, or the negative of that? Is this the number that describes how oblate Earth is?
Code:
Private Sub Command1_Click()
    Dim U As Double, G As Double, M As Double, a As Double, r As Double, C20 As Double
    Dim U2 As Double
    G = 6.6725985E-11: M = 5.97369125232006E+24: a = 6378135: r = 100000000#: lambda = 0.1: phi = 0.1: C20 = 0.00108263
    U = (G * M / r ^ 2) * (1 + (a / r) ^ 2 * P20(Sin(phi)) * C20 * Cos(2 * lambda))
    U2 = G * M / r ^ 2 'point mass
End Sub
Private Function P20(x As Double) As Double
    P20 = 0.5 * (3 * x ^ 2 - 1)
End Function
In the above code, I squared the first instance of r to get acceleration, rather than potential. Is that valid to do in this equation? It seems to behave like I want, with the answer approaching the point mass approximation as r becomes large.
