Frictionless cylindrical flywheel, of diameter 250mm and mass 30k
The discussion focuses on calculating the radius of gyration, final speed, and rotational kinetic energy of a frictionless cylindrical flywheel with a diameter of 250mm and mass of 30kg, connected to a 10kg mass. The radius of gyration is determined using the formula R = √(I/m), where I is the moment of inertia. To find the final speed of the mass when released from a height of 1.5m, the torque and rotational acceleration must be calculated using T = Iω. The kinetic energy at the moment of impact is given by KE = ½Iω².
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with the concepts of torque and angular acceleration
  • Knowledge of energy conservation principles in physics
  • Basic proficiency in using formulas for rotational motion
  • Study the calculation of moment of inertia for different shapes
  • Learn about the relationship between linear and angular motion
  • Explore the principles of energy conservation in rotational systems
  • Investigate the effects of varying mass and radius on rotational dynamics
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotational systems and energy transfer in flywheels.
gk1989
A frictionless cylindrical flywheel, of diameter 250mm and mass 30kg, has a string attached/wrapped on the outside diameter, with a mass of 10kg on the other end.
What is the radius of gyration of the flywheel?
If the mass starts 1.5m form the floor, what will its speed be when the mass is released & it hits the floor? and at this point how much rotational kinetic energy will the flywheel have?
Any hints or answers would be gratefully received.
many thanks
Greg
The radius of gyration should be easy, it's just a simple formula. It's just a function of mass and moment of inertia if I remember correctly. OK, I looked it up, it's just:
[tex]R = \sqrt{\frac{I}{m}}[/tex]
As for the problem let's try and walk through it. From the mass, you will need to convert the equivalent moment that the mass is exerting on the flywheel. From there, you can plug it into the equivalent rotational f=ma equation:
[tex]T = I\omega[/tex] With your moment of inertia and torque/moment, you can get a rotational acceleration. Your mass is 1.5m above the floor, so convert that to radians, and see how long it takes to hit the floor (from the rotational acceleration).
Given rotational acceleration and time, you can now get your final rotational velocity and the kinetic energy which is the equivalent:
[tex]KE = \frac{1}{2}I\omega^2[/tex] Good luck
  • · Replies 60 ·
18K
  • · Replies 23 ·
