Two-Stage Gearbox for Industrial 10:1 Ratio: Advantages
  • Thread starter Thread starter cabellos6
    Industrial Ratio
The discussion revolves around the advantages of using a two-stage gearbox for achieving a 10:1 transmission ratio in industrial applications. Participants explore various reasons for preferring a two-stage design over a single-stage gearbox, considering aspects such as size, cost, load distribution, and thermal management.
  • One participant suggests that a two-stage gearbox may reduce the size of the gears, potentially leading to lower costs.
  • Another participant raises the consideration of tooth load, indicating that a 10:1 ratio may impose different stresses compared to a lower ratio like 2:1.
  • A third participant speculates that a two-stage design could help manage heat build-up in the lubricant, as the friction heat might be distributed over a larger volume of oil due to the load considerations mentioned.
  • Additionally, a participant notes the importance of the relative direction of shaft rotation between input and output in the context of gearbox design.
Participants present multiple viewpoints regarding the advantages of a two-stage gearbox, and no consensus is reached on the primary reasons or benefits.
Some assumptions regarding load distribution, thermal dynamics, and design considerations are not fully explored or defined, leaving room for further discussion.
cabellos6
For an industrial parallel axis gearbox with a transmission ratio 10:1, what is the reasoning behind the use of 2 stages rather than a single stage?
The one I can think of is the reduction in size of the gears using 2-stage as opposed to a single stage, thus reducing costs.
Are there any others?
Also think about the load on a tooth if it is driving a ratio of 10:1 compared to 2:1
I'm not sure about this, but I suspect that it would also ease heat build-up in the lubricant. That would be a result of the tooth-load that Mgb mentioned, in that the friction heat would be spread over a larger volume of oil.
Relative direction of shaft rotation. (Input versus output.)
  • · Replies 69 ·
15K
11K
