Mechanical Engineering - Pin joint Framework problem
The discussion focuses on designing a pin jointed framework to support a cylindrical plug with a diameter of 0.35 m, aimed at preventing leakage in a reservoir wall. The framework is anchored using a pin joint and a roller joint, and the solution involves formulating a system of equations using MathCAD. Key challenges include deriving six equations related to forces (F1, F2, F3, H2, V2, and V3) and applying the three equilibrium equations (sum of Fx, sum of Fy, and sum of torques) to determine support reactions and member forces.
  • Understanding of pin jointed frameworks in mechanical engineering
  • Proficiency in equilibrium equations and static analysis
  • Familiarity with MathCAD for solving engineering problems
  • Knowledge of axial load and buckling concepts
  • Study the method of joints for analyzing truss structures
  • Learn how to apply equilibrium equations in static systems
  • Explore buckling analysis for structural members
  • Practice using MathCAD for solving engineering equations
Mechanical engineers, structural analysts, and students working on static equilibrium problems in frameworks and trusses.
Mactheknife
A framework of pin jointed members has to be designed to support a plug introduced into the reservoir wall to prevent leakage and further progression of a crack along the wall. The plug is cylindrical, has a diameter of 0.35 m and is supported by a single pin joint. The frame is anchored to the ground using a pin joint and a roller joint. Firstly, design the simplest framework to hold the plug in place. The problem is to be presented and solved as a system of equations using MathCAD.
It is deriving the equations on the joints and beams that I am having trouble with.
So far I have a diagram of the frame work:
and have worked out the force that is being excerted on the plug:
But I'm having trouble coming up with the 6 equations involving (F1, F2, F3, H2, V2 and V3). Now I think all of the equations will be equal to 0, apart from the sum of the vertical forces in joint 1 which will be equal to 9808 N, and the sum of the horizontal components in joint 1 which will be equal to 5663 N. Apart from that I'm at a loss and don't really understand how to get the equations.
Any help would be greatley appreciated.
The problem says 'design the simplest..". Thinking ideally and simply, since the force applied at the plug acts 30 degrees below the horizontal, I'd tend to just put in a single member F2, inclined at 30 degrees from the horizontal, and pinned top and bottom, to take the axial 11kN+/- load, and that's it (but check buckling). I suppose, though, a frame works better, in case that the member is not installed exactly at 30 degrees. You gave one example of the supporting truss, but with no dimensions. There are countless others, which may be more economic. Anyway, you just have to apply the 3 equilibrium equations (sum of Fx, sum of Fy, and sum of torques, all each equal to 0),to get the support reactions, and apply the method of joints to get the member forces, using the 2 equilibrium equations sum of Fx and sum of Fy at each joint each equal to zero.
