Making a differential equation of a dynamical system
The discussion revolves around deriving a differential equation for a dynamical system involving a mass attached to a stick, influenced by a spiral spring and friction. The system is described in terms of the angle θ between the stick and the vertical axis, with parameters related to the spring constant and gravitational effects.
  • Participants discuss the concept of the driving moment and its relation to the forces acting on the system. There are inquiries about the correct interpretation of the original problem, particularly regarding the translation from French to English. Some participants express uncertainty about the dimensions of the derived equations and the role of friction in the system.
Multiple interpretations of the problem are being explored, with participants offering insights into the mechanics involved. Some have proposed potential forms of the differential equation, while others are questioning the dimensional consistency and the application of friction. There is no explicit consensus yet on the final form of the equation.
Participants note the challenge of translating technical terms accurately and the potential differences in terminology between languages. The discussion also highlights the need for clarity regarding the forces at play, particularly the spring's behavior and the effects of friction.
eddiechai2003
http://chokleong.com/ESIEE/images/system.png​
[/URL]
A stick, whose mass is neglected, with length [tex]{l}[/tex] is fixed at point [tex]{O}[/tex] on a vertical axis. [tex]\theta[/tex] is the angle formed between the stick and the vertical axis. A spiral spring is attached to the vertical axis and the stick in a manner that when at rest, the stick is in vertical position ([tex]\theta{=0}[/tex]) and the vector [tex]\stackrel{\rightarrow}{OM}[/tex] is parallel to the vertical axis. The spiral spring, with the spring constant [tex]{k}[/tex], applies a force whose driving moment is proportional to the angle [tex]\theta[/tex] on the stick.
At the other end of the stick in [tex]{M}[/tex], there is a mass [tex]{m}[/tex]. Assume that [tex]\mu{=}\frac{k}{ml}[/tex]and [tex]\gamma{=}\frac{g}{l}[/tex], find the differential equation in this form: [tex]\ddot{\theta}[/tex][tex]{=f(}\theta[/tex],µ,[tex]\gamma{)}[/tex]
I am having difficulties with the driving moment. How to etablish a differential equation by taking into account the driving moment and the friction?
Do you have any suggestions?
Thanks.
I have moved this to "Calculus and Beyond" because I cannot imagine doing differential equation PRE-calculus!
But it seems to me that you will need to know at what point on bar the force is applied. Or are you using "driving moment" to mean "force times distance"?
Hello HallsofIvy,
Actually, the original question was not in english. I translated it from french version and I am sure it is slightly different from the original question since I didn't totally understand the notion of moment or driving moment (according to wikipedia). Maybe you know better than me, then you could clarify this part for me.
Thanks.
eddiechai2003 said:
Hello HallsofIvy,
Thanks.
Hey !
I'm fluent in french and have done some mechanics in my first year. Maybe I can help you if you write the original question in french ?
Hello mohlam12,
The french version of the question:
Une tige sans masse de longueur [tex]{l}[/tex], est fixée en [tex]{O}[/tex] sur un axe. On note [tex]\theta[/tex] l'angle formé par la tige et la verticale montante. Un ressort en spiral est fixé entre l'axe et la tige de telle façon qu'au repos ([tex]\theta{=0}[/tex]) la tige soit verticale, le vecteur [tex]\stackrel{\rightarrow}{OM}[/tex] étant orienté vers le haut. Le ressort exerce sur la tige une force de rappel don't le moment est proportionnel à l'angle [tex]\theta[/tex] de coefficient de raideur [tex]{k}[/tex]. On suppose qu'au bout de la tige en [tex]{M}[/tex], on fixe une masse [tex]{m}[/tex].
On note [tex]\mu{=}\frac{k}{ml}[/tex], [tex]\gamma{=}\frac{g}{l}[/tex]. Montrer que l'angle [tex]\theta[/tex] est une solution d'une équation différentielle de la forme:
[tex]\ddot{\theta}[/tex][tex]{=f(\theta;\mu,\gamma)}[/tex].
Sorry everyone, I'll give explanation in french so he can solve it quickly.
Alors on a trois forces, P le poids, R les frottements, et F une certaine force de rappel appliquée par le ressort. En appliquant le principe fondamental de la dynamique de rotation, on a, et en choisissant un sens de rotation approprié, on a
M(P) + M(R) - Mc = J_delta.(teta 2 points) (désolé j'ai du mal avec latex)
Mc étant le moment d'inertie de rappel, qui est égal à k(Teta)
M(P) étant le moment d'inertie de la force P par rapport à l'axe, et qui est égal à mglsin(teta)
M(R) étant le moment d'nertie de la force R par rapport à l'axe, et qui est nul.
J_delta étant le moment du système par rapport à l'axe, et qui est égal à ml²
l'équation devient alors : mglsin(teta) - k(teta) = ml²(teta 2 points)
En remplacant dans cette équation mu et gamma, tu obtiens un truc du genre :
(teta 2 points) + (mu/l).teta - gamma.(sinteta) = 0 qui est l'équation différentielle demandée.
PS : si tu pouvais réécrire mes équations en latex je t'en serais reconnaissant merci !
Hello mohlam12,
Your solution is:
[tex]\ddot{\theta}{+\frac{\mu}{l}.\theta-\gamma.sin(\theta)=0}[/tex]
It seems to me correct but I have doubt since the dimension is not homogeneous.
[tex]{[\frac{\mu}{l}]\neq[\gamma]}[/tex] ([tex]\theta[/tex] and [tex]{sin(\theta)}[/tex] are dimensionless)
I will recheck your solution tonight as I need to go now.
By the way, how can I take into account the force of friction as demanded later in the question : On suppose maintenant que le système est soumis à une force de frottement opposée à la vitesse de coefficient [tex]\alpha>0[/tex].
I am bad in mechanics since I am studying Electrical and Electronics course. My major difficulty is to obtain the corresponding differential equation, after that I can solve the remaining sub questions by my own using matlab.
Hello,
After working for a few hours, I come out with a solution which is "dimensionally" correct. However, I am still not very convinced about the exactitude of the solution since I don't know much about the spiral spring and I couldn't find much information about it on the internet. Below is my solution:
[tex]\ddot{\theta}\pm\gamma.\sin\theta+\mu.l.\theta+\alpha.\dot{\theta}=0[/tex]
By assuming the "moment of inertia" or "moment induced by the spiral spring"= [tex]k.l^2.\theta[/tex] and [tex]\alpha[/tex] is the coefficient of friction.
Is it a plus or a minus in front of [tex]\gamma.\sin\theta[/tex]? It is confusing since the english version and the french version of the wikipedia about the inverted pendulum have different equation.
I want to thank HallsofIvy and mohlam12 for your helps and if you have comments on the equation please don't hesitate write them here.
Thanks.
It seems like I have messed somethings up.
There are 2 different kinds of spring constant. Say [tex]k_L[/tex] for linear springs (compression and extension) and, say [tex]k_T[/tex], for torsion springs.
[tex][k_L]=[\frac{Force}{Length}][/tex] while [tex][k_T]=[\frac{Force\times Length}{Radian}][/tex].
So, mohlam12, your solution was correct. It was my fault to not verify things carefully.
Here again, the solution is:
[tex]\ddot{\theta}-\gamma.\sin\theta+\frac{\mu}{l}.\theta+\alpha.\dot{\theta}=0[/tex]
Am I right?
